Look Ma! My First Post!
rear end noise
2002 ford mustang loud popping from rear end while turning forward or backing
sounds like something is loose. ck the control arm bolts , shocks, caliper brackets, etc.....
make sure your tail pipes arent loose or close enough to knock on anything cause i had that problem a few times when i had tail pipes and it sounded like it was coming from the rearend.
95' GT is being reconstructed! |
sounds like a gear issue maybe.
It's your control arm bolts. Get under there and tighten them down and it'll sound as good as new.
Check bushings see if they are cracked or deteriorated
Look Ma! My first post!
Posts: 1 Joined: 17 May 2007 Posted: Thu May 17, 2007 5:05 pm.... he's not coming back
Threads Similar to: rear end noise
| Rear Noise | Timmytattoos | General Tech | 1 | March 21st, 2008 06:51 PM |
| Noise from rear - vid | tomzac | Modular Mustangs | 1 | October 8th, 2007 11:12 AM |
| noise in the rear | 4.6gtmarine | 99-04 | 2 | November 6th, 2006 08:15 PM |
| Rear End Noise. Help. | Invictus | 99-04 | 16 | August 15th, 2006 10:22 PM |
| Noise in rear end | OTreborO | 5.0 Mustangs | 3 | August 7th, 2006 05:47 PM |
