stupid car troubles
Old August 11th, 2011, 07:45 PM   #1
Hardcored Manthusiast
LegendEleanor's Avatar
2005 Cervixi Mustang
really gay
LegendEleanor has a spectacular aura aboutLegendEleanor has a spectacular aura about
stupid car troubles
Lately my car has been having some minor issues. At first it was that my battery was dead. I jumped it and then it was fine. then a few days later I had to jump it 2 more times. there was battery acid all over one of the connectors so I cleaned it and thought that was the end of it. maybe I would have to get a new battery. Then when I started my car it was idling really low. and then it just started sputtering and it died. Then it would turn over and start fine, but immediately lose power and die. So I didnt drive it all yesrerday. Now today its idling really high. Not sure what the problem is.. any help?
Old August 18th, 2011, 09:02 PM   #2
FordGT is on a distinguished road
I would first replace the battery. It sounds like a post is cracked/leaking. Then I would check to see that the cables are not corroded. If it's just the ends that are corroded you can cut them off and replace the terminals as long as you have enough reach left. It'll be hard to diagnose another problem with a faulty battery so that's where I'd start, just my 2 cents.
Old August 27th, 2011, 10:31 AM   #3
Majrdad's Avatar
2009 Warrior In Pink
Majrdad is on a distinguished road
Legend - did changing the battery fix the problem?
Old August 27th, 2011, 03:55 PM   #4
Look Ma! My First Post!
Randy B is on a distinguished road
2006 Ford Mustang Gt
MY dome light stays on when driving. When stopped (key out) it takes about a half hour for it to turn off. Also, if there is a sensor, where is it? HELP.
RANDY
Old August 27th, 2011, 05:22 PM   #5
00MustangGtPremium's Avatar
2000 Mustang Gt
no clue
00MustangGtPremium is on a distinguished road
Is it throwing any codes?
Just because your cars loud doesnt mean its fast
Old August 27th, 2011, 05:24 PM   #6
2000 Mustang Gt
no clue
RANDY
Try messing with your dimmer switch and I believe the switch is in the door jamb by the door hinges. I own a 2000 so it might be different.
Old September 8th, 2011, 03:39 PM   #7
really gay
I never did check back on this thread. Battery was dead. replaced it. and I had to replace my fuel rail sensor.. Ive heard those go bad quite often on my year mustang
Old September 13th, 2011, 08:59 PM   #8
5.8mustang's Avatar
1988 mustang lx
never ran down a track
5.8mustang is on a distinguished road
randy b the door sensor is in the latch i believe i haven't worked on alot of 06 mustangs but i believe thats were it is
Threads Similar to: stupid car troubles
Ahhh troubles, troubles. 02trueblueGT 99-04 1 August 20th, 2010 06:49 PM
having some troubles roosgt! 99-04 2 August 12th, 2010 12:20 AM
stupid, stupid, stupid question re: wheels ReverendDexter 4V / SVT 6 December 18th, 2008 12:41 AM
Troubles... sxynerd 96-98 3 July 29th, 2008 08:36 AM
still have troubles krispy V6 Mustangs 2 July 14th, 2008 02:58 PM
