Rear gear size
Old May 30th, 2006, 03:52 PM   #1
charliemopps24 is on a distinguished road
Send a message via AIM to charliemopps24 Send a message via Yahoo to charliemopps24
Rear gear size
What size is the rear gears on an 89 LX 5.0? 8.8 or 9" or, i shudder to think, a 7.5?
Old May 30th, 2006, 04:39 PM   #2
mdvaldosta's Avatar
11.47@120.58
It's 8.8 - the 7.5's were used in 4 bangers Mustangs and pre '86 5.0's. 9" rears weren't ever put in the fox body platform (79-04) Mustangs, but can be swapped in with some finesse (although practically never needed).
Old May 30th, 2006, 05:51 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yep, what mdvaldosta said.
Old May 30th, 2006, 07:24 PM   #4
Bossman351 is on a distinguished road
Send a message via AIM to Bossman351
I helped a friend swap a 9" into and 84 lx and it was fairly easy. the part that requires the most finess is welding the brackets the the housing and getting the angles all right.
Old May 30th, 2006, 07:41 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
There are so many companies that make bolt in 9" housings and assemblies now it really isn't worth the hassle to fabricate one that will work anymore. A 9" really isn't necessary until you are making over 1000 hp.
Threads Similar to: Rear gear size
stock gear size oannamarie 96-98 4 September 7th, 2007 07:06 PM
WHAT SIZE GEAR RATIO? bluebyu 5.0 Mustangs 10 August 25th, 2007 06:14 PM
Distributor Gear size hitorx 5.0 Mustangs 1 July 5th, 2007 01:35 PM
Rear end size VDub1285 Modular Mustangs 2 January 16th, 2007 03:05 PM
94 GT what size rear end? stang94 5.0 Mustangs 2 December 6th, 2006 09:31 AM
