Discussing solenoid after solenoid after solennoid in the General Tech Forum. I have to keep buying solenoids even if i put it in and stored the ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
unhook the little wire on the 'I' terminal, hook-up the batts, install a voltmeter to the wire (black to batts (-), and red (+) to wire)...
ck your reading with key off, key switched on, key in start position, then key in released position, and then key off again. try several times and verify all readings...should have 12volts in start position only.
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
Make sure you are using the correct solenoids. All the eec-equipped cars and trucks have a diode built inside the solenoid. Use of an early solenoid on them will result in failures like you describe
88 Mustang Coupe 2006 FFW Richmond True Street Runner-Up www.rickscarcare.net http://img146.imageshack.us/img146/2158/ricksadql2.jpg |
#4 | |
Maintenance Man
11.47@120.58
sometimes it comes in handy to be the resident old fart
i use the one that the auto parts store says is for an 88 5.0 but my car started out as a 4cyl efi but is now a carbed 5.0 and i'm using a dura spark ignition setup from an 85
That will work, I still have the solenoid on my mustang when I converted, never had a problem.
Be sure you have a very good connection on your electronics such as your Duraspark ignition system, solenoids. If you are running a O2 just to grab A/F, make sure the o2 is clean LOL. I have to do the same thing soon to mine...It stays on rich because it probably carbonized by now
THE BEAST IS FOR SALE!!! GTX RACING & PERFORMACE CLUB OF TEXAS Meets and greets, drag racing and good eats, you know you want it. GTX Racing Tony P. 214-257-3635 http://www.moddedmustangs.com/forums...vehicle&CID=43 |
I dont think its the solenoid I think its the ignition switch
I agree! or a wire shorted to another. Something else overlooked is grounds! weak grounds strain coils and such (the solenoid) by searching for a ground to correctly function and essentially this burns up the coil.
i have a problem that this room might help with. i just bought a 90 mustang that was converted from a 4-cyl to a 351W. when i try to crank it, it clicks at the relay behind the left fender but no other noise or engine turnover. the starter was already replaced twice and the batt. is new. any ideas??
I FOUND IT!!!!!
the screw that holds the cablle on the starter was two long and it was grounding on the body of the starter
well it turns out thats not it. but i found if i tap the solenoid it fixes but i shouldnt have to do that, whats cuasing this.....its 3 new and different brands of solenoids
The Cable Guy...
SLOW
I had the same problem in my 91 5.0...It ended up beign the starter...I went through literally 10+ solenoids in a very short time...
i bought a brand new starter befor i stored it and when i took it out the problem was back
Threads Similar to: solenoid after solenoid after solennoid
| How can u tell if its the starter or the solenoid? | noyz25 | 5.0 Mustangs | 11 | October 28th, 2007 09:48 AM |
| EGR Solenoid | dgt_mustang | V6 Mustangs | 12 | October 20th, 2007 03:15 AM |
| Starter/solenoid problem | WIKD | 2.3 Mustangs | 2 | October 4th, 2007 07:15 PM |
| starter solenoid question | fastford3388 | 5.0 Mustangs | 2 | April 23rd, 2007 10:40 PM |
| Starter solenoid? | 8A_Honda | 5.0 Mustangs | 9 | March 13th, 2007 12:23 AM |
