vibration
Old May 31st, 2006, 01:56 PM   #1
cali 5.0 is on a distinguished road
vibration
in ma 89' gt whenever i pull off from tha light i can kinda feel a vibration coming from somewhere but im not sure where it is, its coming from the front passenger side of the car,, do u think that i need to replace the control arm bushings?? wht do u think is causing this
Old May 31st, 2006, 04:13 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Clutch, driveshaft, u-joints, torque converter, transmission, rear axle, exhaust and transmission mount (just to name a few things) could cause what your describing.
Old May 31st, 2006, 05:09 PM   #3
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
well if its coming from the front passenger side, could be your inner tie rod, wheel bearing maybe, but that would make noise.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Threads Similar to: vibration
Vibration graystang01 V6 Mustangs 21 December 15th, 2007 11:23 PM
vibration haywood11 5.0 Mustangs 2 October 28th, 2007 08:41 AM
Vibration shurb125 5.0 Mustangs 13 May 8th, 2007 09:23 AM
vibration hmotes 5.0 Mustangs 8 January 5th, 2007 02:30 PM
vibration cali 5.0 5.0 Mustangs 7 June 8th, 2006 07:44 PM
