problem starting
Hi,,
i just finished my motor and sc install,the car will only start if i hold the pedal to the floor,,then it starts and idles fine.couple ?'s what would be a good starting point for fuel pressure and base timing,also wht should the wideband read at idle,, thanks steve |
RLY SRS
At idle I see it boune 14.7 - 15.4...
Hows your fuel pump? Your fuel regulator?My fuel pressure at idle sits right around 40...But I have a mod engine so mine is prolly different... |
hey ,,
fuel pump in tank is a 255 walpro(new) new t-rex pump fuel pressure is around 40-41 at idle at idle i bounce from 14.9 - 15.9 regulator is new also aeromotive |
RLY SRS
Do you turn the key foward and let the fuel pressure get to the right level before you start it?
Try that and see if it works then... |
i'm running 42#'s,yea,,i turn the key and wait a second for the wideband to cycle and the fuel pressure come up,i'm gonna check the tps and iac(which is new),,
heres a pic of the motor
it's set at 42 with the vacum line on,,
Is that an FMU on the passenger side? If so, you shouldn't need it if you run 42's. I run the stock FPR with 42's, ditched the FMU and have 32 lbs of fuel pressure at idle.
ok,,,,i'll try that,i'm new to the whole sc'd scene.is the 32#'s of fuel pressure be set with the vac line on or off the regulator.also. could the 42's set at 40#'s with the fmu be causing the hard start,
thanks |
Keep the vacuum line on the FPR so it will work the way it was intended. Stock FPR's are 1:1 boost referenced so it will raise fuel pressure with boost as needed. Has your car been to a tuner since you sut the SC and 42's on it?
no..the car hasnt been to be tuned,,i just finished installing the new motor and sc.i have a aeromotive fpr also not the stock fpr.
hi..
well,,ran the car last nite again,,talked to a friend who does tuning. the cars going in a week from this sat to be dyno tuned and a custom chip burned. 200 for the tune 300 for the chip,does that sound right
Threads Similar to: problem starting
| Problem w/ Starting Car | Speedstang302 | 5.0 Mustangs | 21 | October 29th, 2007 09:48 AM |
| Problem starting up | sbx213 | 5.0 Mustangs | 5 | March 11th, 2007 11:46 PM |
| problem starting | mustangman0001 | 5.0 Mustangs | 3 | March 4th, 2007 01:52 PM |
| Starting Problem | 97_4.6L_Stang | Modular Mustangs | 5 | January 23rd, 2007 10:01 PM |
| Car Starting Problem In My 03 GT | autostang03gt | 99-04 | 3 | November 13th, 2006 01:09 AM |
