Look Ma! My First Post!
1990 Mustang GT
90 GT fuel pump failure
Hey, I have a problem with my fuel pump not turning on and priming the system. The fuse, and relays are fine, and the inertia switch is still pressed down. It's a Walbro 190 lph pump. It has done this to me 3 separate times, once a year ago, then a few days ago and now yesterday. I think it might just be like a loose wire going down to the tank or something. Is there anything special I should look for?
I would check for voltage in the wiring, starting at the fuel pump all the way to the ECU (which I think is the problem), while doing it, twist and shake the wiring too, Also check all the connectors for corrosion etc.
Threads Similar to: 90 GT fuel pump failure
| the P0411 code: secondary air pump failure | wjs1820 | V6 Mustangs | 2 | September 8th, 2010 07:49 AM |
| Oil Pump Failure/Possible Rebuild | bigz5000 | 4V / SVT | 5 | May 26th, 2010 11:08 PM |
| Boost-A-Pump or GT500 Fuel Pump? | stanglifemike | 2005 - 2010 | 64 | September 21st, 2009 01:17 PM |
| Fuel pump question. Stock GT pump to GT (supercar) pump. | Nate's4.6 | 99-04 | 15 | May 14th, 2008 02:25 PM |
