Question About Convertible Top Components
Old September 2nd, 2011, 03:06 PM   #1
laser98 is on a distinguished road
Does anyone know if the top latches for the 94-98 convertibles are adjustable? The one on the driver side isn't pulling the top down all the way and I didn't know if I could just adjust it somehow or if I need to replace the latch. Thanks.
Old September 2nd, 2011, 03:07 PM   #2
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
my little latches have thick rubber around them, maybe your rubber is missing?
as far as adjusting them i have no idea
also have no idea what year car we are talking about lol
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old September 2nd, 2011, 03:14 PM   #3
It's a 96 model. I don't have the rubber thing that you mentioned or at least I don't think I do lol
Old September 2nd, 2011, 03:15 PM   #4
2002 mustang gt
12.2 at 117
is the latch loose?
Old September 2nd, 2011, 03:19 PM   #5
It's kinda hard to say. When I close the top, the top comes down and the posts on each side seat into the frame. When I push the latch shut on the driver side, the hook that grabs the frame and pulls the top down snug doesn't pull it down all the way so the driver's side doesn't fit flush.
Old September 2nd, 2011, 08:28 PM   #6
Anyone got any ideas?
Old September 5th, 2011, 02:51 PM   #7
2002 GT Convertible
achamb7 is on a distinguished road
There is a set screw (hex head) that you need to loosen; then twist the J-hook clockwise to tighten, counterclockwise to loosen. Make sure it lines up correctly, then tighten set screw. Hope this helps.
Old September 7th, 2011, 10:27 AM   #8
Awesome! I saw that when I was searching around but didn't realize it adjusted the J-hook. I just thought it was there to remove/install the hook. Thanks so much! I thought I was gonna have to come up with $150 for a new friggin latch! Hopefully this will fix it!
Threads Similar to: Question About Convertible Top Components
Convertible Mustang question Abe 2011+ V6 12 April 6th, 2011 10:08 AM
Convertible Question... HurrycaneStang 2005 - 2010 2 August 23rd, 2010 12:46 AM
Convertible Top Question b1gdaddy98 V6 Mustangs 9 February 19th, 2010 12:13 PM
Convertible question Mistertribal 5.0 Mustangs 14 April 15th, 2009 06:40 PM
94 Convertible top electronics question. Need Help decibels5 94-95 0 March 5th, 2007 06:08 PM
