01 True Blue v6
to slow to matter
Lean issue, need advice
Alright. I am chasing down a lean issue, even after getting it tuned. When coming to a stop, my car will go completely lean and start stutering. Sometimes after around 5 seconds, the afr will shoot back up to normal and the car will idle fine. I have checked for vacuum leaks and have actually replaced all the gaskets from the lower intake up. Also, when I'm at part throttle (usually no more than 30%), the afr will shoot to 17 and 18, and often completely lean. What could cause this?
2001 3.8L Mustang D1-procherger w/ 2 cor intercooler 3.60" pulley 39# injectors HPX blow through 75mm MAF SVT focus fuel pump /w wiring upgrade plx wideband Windstar upper intake P&P lower comp cam- 218/226 , .500/.500 lift, 108lsa 118 beehive springs and retainers Mac long tube headers o/r H pipe into dual flowmasters Eibach pro-kit Tokico shock/struts Detroit true-trac w/ 3.73 gears pro 5.0 short throw shifter Also had my egr deleted, pats turned off (or bypassed), rear O2 sensors turned off, and my imrc's deleted. |
2009 Warrior In Pink
I might offer MAF sensor cleaner as that helped me after installing a new CAI. Cost me $6 and 15 minutes and helped me.... Good luck!....... Ken :-)
Threads Similar to: Lean issue, need advice
| gas gauge issue sage advice needed | shamrock81887 | 5.0 Mustangs | 20 | August 11th, 2011 03:18 PM |
| Any advice on my stalling issue? | TinyWeyant | 99-04 | 2 | March 17th, 2011 11:15 PM |
| Need advice on shifting issue | cobracutie3 | Modular Mustangs | 4 | November 16th, 2010 10:10 PM |
| need advice with shifting issue | cobracutie3 | 99-04 | 7 | November 10th, 2010 12:31 PM |
| lean really lean plaese help 331 stroker | stangzilla 331 | 94-95 | 8 | January 30th, 2010 06:58 PM |
