1995 Mustang Gt
Well i got my lowering springs today but..
was it worth it? I havent installed them but i found a set on CL for 120 bucks. Its the eibach pro kit lowering springs NOT the sportline. Was it a good buy?
how much is the drop if anybody knows. thanks
95' GT, Trickflow setup, Aluminum heads with 1:6 roller rockers, e303 cam, BBK shorties into Magnaflow exhaust, BBK cold air intake with 75maf, Highperformance waterpump w/ electric fans |
1995 Mustang Gt
also, i was told to cut a half inch coil off the front cause it will sit higher then the back. Should i do this? I know from ppl that if you cut your springs it will not be level anymore thus causing sitting problems. Thanks guy
Priest of the Car Gods
I wouldn't cut a set of new aftermarket springs, but if you do want to cut them, don't just lop it off, make the area where you cut it off replicate how the stock piece looked. If it's flat, find a way to make the spring flat after you cut it.
1995 Mustang Gt
they are used btw...
1995 Mustang Gt
shop said do not cut the springs. NOW...i heard on here that to just leave off the insulators inside the rear springs..should i? whats the benefit besides the noise control?
Yeah, there's a huge debate over cutting springs. I'm on the side that says cutting springs is fine so long as you understand what you're doing and why cut springs have the bad rap that they do.
I'd imagine that any shop is going to say not to do it if for no other reason than the liability involved.
1995 Mustang Gt
i want 2, just bc i know these springs will leave my front a lil higher then my rear which is exatcly the opp. look i want for this car...so im still torn on doing it myself with a half wheel saw gun...?
#8 | |
Disturbin' The Peace
2003 Mustang GT
![]() ![]() ![]() ![]() ![]() iTrader: 8 reviews
If it is a progressive rate spring, I wouldn't cut it. Pretty sure the pro kit is progressive.
Linear rate is a different story.
![]() 2003 Mustang GT STD 259rwhp 298rwtq
Authorized Vendor
![]() 1987 Mustang LX 5.0
DO NOT CUT YOUR EIBACHS!
Eibachs are progressive-rate springs which means the more they compress, the more stiff they get. If you remove the "softer" portion of that progression you are going to be riding on some VERY stiff springs. Put the springs in and see how they look. If you want it lower or higher in the front, play with the isolators to find which combination of having them or taking them out will get you the best look. Did you buy Caster/camber plates for the springs? You are going to need some way to adjust camber for the lower ride height.
Chris Young | AmericanMuscle.com Toll Free: 866.727.1266 | M-F 9AM-9PM EST | Sat 10AM-4PM EST Bama Hotline: 888.226.9764 | M-F 9AM-5:30PM EST | Sat 10AM-4PM EST GET UP TO $200 TOWARDS YOUR NEXT PURCHASE FROM AM! Free Same-Day Shipping! |
Just remove the isolators first before cutting the springs. The ride will suck afterwards trust me.
![]() Sig by Tricep |
OP put them in and see how they look after a few weeks with the isolators in...if you find the fronts not going lower then pull the front isolators. its not hard to pull springs so changing isolators in and out isn't a big deal.
1995 Mustang Gt
thanks guys, really. i will not cut the springs so i guess il just see how they look and jus loose the isolators. what do they do though?
ISO'w will quiet done the noise of the spring making contact with the k-member basically.
If you take the original coils out of a 96-04 GT Mustang........cut 3/4 of a coil from the
bottom of the front........and 1 full coil from the top of the rear........using a dremmel tool and a cup of ice water.......the car will drop 1-1.5" and sit level........I know....i've done it.......but as for cutting on aftermarket lowering springs......DONT DO IT......i've done that also and ruined the spring......... |
#16 | |
although your cutting measurements are either a bit off or you're using some really old springs that aren't holding up right...my last two stangs recieved 1.25 coils cut off the front and 1 coil off the back to recieve close to a 1.5" drop |
Bringing Yellow Back
lol fuck yea to cutt stock springs
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
Threads Similar to: Well i got my lowering springs today but..
| Drag springs or lowering springs??? | AggieStang | General Tech | 10 | February 18th, 2012 12:45 PM |
| stock springs vs lowering springs in drag | TotoGT06 | 2005 - 2010 | 4 | April 14th, 2010 10:25 PM |
| lowering springs | BWAL | 96-98 | 23 | January 16th, 2009 08:46 PM |
| Lowering springs... | MeMz | 96-98 | 28 | January 13th, 2009 11:08 AM |
