brake repair
Old June 3rd, 2006, 06:47 PM   #1
Look Ma! My First Post!
whitestang is on a distinguished road
brake repair
first time rear brake replacement........having problem depressing caliper piston on 97 v-6........can any body help?
Old June 3rd, 2006, 07:22 PM   #2
Screemin3o2 is on a distinguished road
Send a message via AIM to Screemin3o2
Are there two notches on the outside edge of the piston? Most ford cars have that type of piston on the rear caliper, I'm not sure if it's that way on v6's of that year. If you don't, the don't bother reading anymore. If there is, there are a few different ways you have to do it. You might need some help of someone to hold the caliper. It's a pretty complex design behind the piston inside the caliper. I don't remember exactly how it works but I know that it deals with a nut that is threaded behind the piston for the piston to compress in. A lot of peopel think that its the piston that is threaded but it is not. When it decompresses, it acts as a normal piston by sliding right out and pressing the pads against the rotor, but when it is compressed again it has to be turned. One of the ways you can do this is pick up the actual tool that slides in the notches and is like a socket and you turn it with a ratchet. You can get a big set of needle nose pliers and put the edges of the pliers in the notches and turn it that way. You can also slide the seal back a little bit and grab the outside edge with a set of channel locks and turn it that way. Now, there will be sets of notches (lack of a better word) on the back of one of your pads also. Those notches slide in the ones on your piston. That is what keeps the piston from spinning anymore. Since you have to use those notches, you have to compress the piston exactly where the notches will fit exactly with the pad. Hoped all that helped.
95 Mustang GT
Slow Bolt On Car
www.steelcitystangs.com
Old June 3rd, 2006, 07:30 PM   #3
mdvaldosta's Avatar
11.47@120.58
Not sure about the back, may need that square socket tool for your ratchet like screemin said, or if it's like the front I take an old pad, lay it against the piston, and use a c-clamp and slowly push it in. I've even done it pushing by hand, but I'm not sure you've got the superhuman strength I have
Old July 21st, 2007, 01:58 PM   #4
172pilot is on a distinguished road
Can you show a link to a webpage to buy this tool, and/or tell me what it's called? I've been to two parts stores, and they give me a blank stare like I'm crazy.. Never heard of turning caliper pistons...
Thanks for the needlenose idea. I was going to try that, but now that I know it works, I'll try more than once before cussing and giving up! ;-)
Old July 21st, 2007, 02:04 PM   #5
HMUSN's Avatar
iTrader: 9 reviews
Ford Tool T87P-2588-A
Old July 21st, 2007, 09:41 PM   #6
mikebert is on a distinguished road
Send a message via AIM to mikebert Send a message via MSN to mikebert
Do you have a brake caliper compressor? Just go to Autozone and buy one.
Old July 31st, 2007, 08:06 AM   #7
acehogg69's Avatar
06 GT with bolt ons
I sucked
acehogg69 is on a distinguished road
Our rent one, but they are pretty cheap to buy.
Kyle Busch Haters Club!! Member Uno!
Tony wrote "Blowers blow, turbos suck, and nitrous rules!!! lol "
Borla cattless L/T's topped with Flowmasters , Roush short throw, JLT2 CAI w/ X-CAL2 from Brenspeed, Bullit 18X9 and 18X10 deep dish.
Threads Similar to: brake repair
ecu repair ecu repair 5.0 Mustangs 1 October 6th, 2007 05:53 PM
Cowl repair for a '68 6T8coupe Classic Mustangs 12 August 3rd, 2007 04:12 PM
Brake repair lbienemann General Tech 3 April 13th, 2007 11:54 AM
Repair Questions wilburgtwoot Visual 2 February 22nd, 2007 02:12 PM
Do it your self A/C repair Roadhawg The Clubhouse 2 July 29th, 2006 08:26 PM
