LinkBack (1) | Thread Tools |
#1
No start, theft light (96 mustang gt)
About a month ago the universal joint snapped, break both o2 sensors with it, and 2 weeks after that my 96 Mustang gt dies on the way to work. The theft light blinks and it not start.
I had the guy who towed it take it to their shop, but after a few days they told me the PCM needed to be replaced and programmed by the dealership. So I talked to the dealership today after its been there since Friday, and they tell me they want to change the (2) o2 sensors for $700. Would the o2 sensors cause theft light/no start problems, even after I had been driving around without them for about 2 weeks? I'm guessing they won't be willing do anything else till this is fixed because of how they troubleshoot. The dealership hasn't said anything about a PCM change. What should I do? I don't think paying them $700 to change two $50 o2 sensors will have my car running. |
2000 Mustang Gt
no clue
The O2 sensors (as you probably already know) is for emissions so I dont think it would cause your problem. Id see if they could reprogram the PCM first before they replace it. Also the O2 sensors arent that expensive so its your choice if you want to replace them yourself or let the stealership do it for a mountain of cash
Just because your cars loud doesnt mean its fast |
I wasn't in a hurry to replace the o2 sensors but the way they are talking is that since its the most obvious thing wrong with the car(besides it not starting) that COULD be the problem. If they won't/can't work past that I'm thinking about changing them out in the parking lot up there but I don't know how much BS they will give me.
As far as the PCM, the first guys who looked at it said that it needed to be replaced and reprogrammed, would this more likely be the case by whats going on with the car? How likely is an aftermarket entry/alarm to be the cause of this? It's been in there about a year. |
2000 Mustang Gt
no clue
If the PCM is not working the car wont work. Either the PCM got fried or the aftermarket alarm system disabled your car (killswitch). Also just swap out the O2 sensors yourself and save the money
#5 | |
From the dealers diagnosis: "A ck car died out will not crank. see adv. 11FOZ01 ENGINE CONCERN 59203 CC 121987 Verified customer concern. Ran e/e/c/ test performed pinpoint. Found odes for rear 02's inspected 02 sensors found 02 sensors damaged and cioonnectors and wiring damage. Unable to perform additional diagnostics until above items are replaced and repaired. May need additional work. B Multipoint inspection 00foz99p multi point inspect 59203 cc" |
#6 | |
2000 Mustang Gt
no clue
2000 Mustang Gt
no clue
Chances are that the shop didnt disable PATS when they installed the aftermarket alarm system. You said that your car will turn over and then immediately stall right? Its either because PATS has disabled the PCM or the PCM is damaged.
Thanks for the replies.
Payed 100 to the ford dealer today for their 'diagnosis,' and payed another 65 to have it towed to my house today. Had my neighbor look at it and he replaced a fuse that the first shop blew up 2 times, and... it started up. WTF? Im glad it works but what the hell were these two places doing? Did my electrical problem somehow get fixed between the 5 towings? Going to ford tomorrow to get my money back. I remember checking fuses soon as it died too, hmm. Last edited by optiquest; October 27th, 2011 at 10:53 PM. |
#10 | |
2000 Mustang Gt
no clue
2001 Ford Mustang Cobra
The dealership was trying to take you to the cleaners. They probably knew about the fuse and where going to replace the o2 and fuse and tell you the o2 where the cause and laugh as they cashed your check. That sound like a dealership I would stay a way from. If there techs seriously thought the o2 sensors would fix that problem I would have call BS immediately and taken it somewhere else. They should know good and well o2 sensors aren't going to trip the Theft.
Glad it was an easy fix, which fuse was blown?
2001 Ford Mustang Cobra---1993 Notch Colorado Car Forum Bringing Horsepower Junkies together!! |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/general-tech/237534-no-start-theft-light-96-mustang-gt.html
| Thread Need advice!! My theft light it blinking | Forums at Modded Mustangs | BoardReader | This thread | Refback | December 6th, 2011 01:42 PM | |
Threads Similar to: No start, theft light (96 mustang gt)
| Theft light blinking, car will not start. | 3.8mustang98 | Electrical & Wiring | 1 | October 4th, 2011 03:00 PM |
| Car wont start, no power to anything but theft light flashing | NeoStang | V6 Mustangs | 28 | April 7th, 2011 01:24 PM |
| Theft Light, Car wont start...HELP | puss84 | 99-04 | 9 | February 21st, 2011 07:21 PM |
| Car won't start: Flashing Theft Light | Fhernando | V6 Mustangs | 10 | October 26th, 2010 11:07 PM |
| Car wont start Theft light on **HELP** | PapaSmurf | 99-04 | 4 | September 27th, 2008 09:28 PM |
