was told I had all this that needs to be replaced?
Old November 4th, 2011, 12:32 AM   #1
zinsavage123's Avatar
2001 Mustang GT
12.33@111.23mph
zinsavage123 will become famous soon enough
8.8 Pinion Seal
8.8 Upper Housing Bushing Kit
MODULAR REAR MAIN SEAL
MODULAR FRONT CRANK SEAL
2V TIMING COVER GASKET
now I seen no leaks and nothing drips from my gt, so I dont know if its major or not the shop told me its not 911 worthy but should be fixed in the near future. Are these serious repairs if not attentended too quickly? any negatives too putting this off for a lil while? does this stuff go up at low miles? I only got 75k on it!??
2001 Mustang GT - mods+pics in garage, tuned by matt@performance evolution
1996 Civic DX - my dd
Old November 4th, 2011, 12:49 AM   #2
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
Zatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud of
iTrader: 15 reviews
Most of it just looked like basic seals, besides the brushings... not sure about that.
Whats the cost on all if it? If its not much, there is no harm.
Black Bullitt Rims FT/FS
Looking to Sell or Trade for Silver FR500s
Looking to buy a lot of 99-04 Interior Pieces
If you have any for sale, PM me
Old November 4th, 2011, 01:13 AM   #3
2001 Mustang GT
12.33@111.23mph
quite a few hundred whats the upper bushing kits? now will I mess anything up or have problems if some of those seals/gaskets leak and I dont fix right away?
Old November 4th, 2011, 09:24 AM   #4
Disturbin' The Peace
4.6DreameR's Avatar
2003 Mustang GT
4.6DreameR is a glorious beacon of light4.6DreameR is a glorious beacon of light4.6DreameR is a glorious beacon of light4.6DreameR is a glorious beacon of light4.6DreameR is a glorious beacon of light
iTrader: 8 reviews
The upper bushings are the UCA bushings pressed into the 8.8 housing. Stock ones are rubber, replacement can be either rubber, spherical, not sure about poly. I haven't seen them.
If its not leaking, don't mess with it.
Rear main seal is a pain to get to and replace.
You are going to pay quite a bit for it, there is a lot of labor involved replacing the rear main and timing cover seal.
The only other thing that comes to mind immediately is the oil pan gasket. Mine is leaking slightly, but I never see more than one drop every now and then on the driveway.
Good thing to replace when dropping the Kmember for any reason, be it LTs or replacing the K with a tubular one.
2003 Mustang GT
STD 259rwhp 298rwtq
Originally Posted by L
In the 21st century, information is power, to where any human being can learn how to do anything with the touch of a button. With that the most powerful thing a person can do is share ideas and information.
Old November 11th, 2011, 01:02 AM   #5
2001 Ford Mustang Cobra
fox_body_stang is on a distinguished road
Sounds like the shop is looking for a way to get some cash out of you. If you can't see it leaking then don't worry about it. I'm curious how they came up with the rear main seal without pulling the tranny to see something, unless they were seeing something leaking. The upper control arm bushing is a PITA to change, so unless you are really noticing something detrimental in the feel of the rear suspension I don't think I would worry about it. Those bushings are something you would worry about if you had the rear end out and could have some room to work. I would say there is no harm in putting off unless it is gushing out of the seal. If it is leaking slightly then just make sure to keep an eye on the oil level and make sure you are keeping it at optimal level.
2001 Ford Mustang Cobra---1993 Notch
Colorado Car Forum
Bringing Horsepower Junkies together!!
Old November 14th, 2011, 08:09 PM   #6
mustang50lx's Avatar
mustang50lx is on a distinguished road
If the seals are really leaking make sure and check the PCV valve/system. If it's clogged the excessive crankcase pressure can cause seals to leak. It used to be a problem on 5.0 pushrod engines when the PCV filter got clogged on higher mileage cars. I am surprised they are leaking with 75K on the car. My wifes 92 Grand Marquis went to the junkyard with 320K on it and no leaks. I would get a second opinion for sure.
Old November 14th, 2011, 10:21 PM   #7
2001 Mustang GT
12.33@111.23mph
well I got a built trans and stall put in not too long ago and I dont beleive he said anything bout the rear main seal? so???
Old November 14th, 2011, 10:23 PM   #8
2001 Mustang GT
12.33@111.23mph
true and i have looked under the car while at idle and operating temps not one drop of anything is dripping so who knows on that?
Old November 24th, 2011, 01:08 AM   #9
Well then definitely sounds like a shop trying to screw you out of mod money.
Colorado Car Forum
Old December 5th, 2011, 10:12 PM   #10
03fastgt is on a distinguished road
Threads Similar to: was told I had all this that needs to be replaced?
cause i do what im told ( CL add ) thrasher! The Clubhouse 12 April 17th, 2011 08:37 PM
I won't say I told you so.....but I told you so 03SonicBoom The Clubhouse 20 January 24th, 2010 11:41 AM
this is what i was told, help mlessor96GT 96-98 6 June 19th, 2009 05:16 PM
Some guy told me... Dansby The Clubhouse 13 October 27th, 2008 08:40 PM
i was told to mustang1072 V6 Mustangs 2 May 14th, 2007 02:31 PM
