Look Ma! My First Post!
front turn signal bulb
how do you replace a front turn signal bulb on a 2002
You need to pull the 2 tabs behind the headlight unit. They pull straight up and out. Then you can slide out the unit. Be careful with disconnecting the wire harness to the bulbs. The tabs will break very easily. Then remove the headlight. The turn signal bulb will unscrew then come out from the side of the headlight.
How to replace the headlights on a 99-04 Mustang | Video « Wonder How To This vid will help you out more then I can describe. ![]() Good Luck it is very easy to remove a headlight.
![]() Sig by Tricep |
Threads Similar to: front turn signal bulb
| Front Turn Signal Hanging | E_TeL | 2005 - 2010 | 18 | March 10th, 2011 11:31 AM |
| parking light/turn signal bulb sizes | beastGT | 2005 - 2010 | 6 | December 16th, 2010 09:20 PM |
| Turn Signal | Youngin | The Clubhouse | 11 | August 18th, 2007 09:20 PM |
| halo and projector headlight and front turn signal recalls | spicetraders | Audio/Video | 4 | December 1st, 2006 09:52 PM |
