Best way to clean plugs
Old November 23rd, 2011, 09:52 PM   #1
Huck's Avatar
2010 Mustang GT
Huck is on a distinguished road
Car was running rich and my plugs are pretty nasty. What is the best way to clean the spark plugs? Can I use the wire wheel on my grinder?
Sons of Liberty
Steeda CAI, Delete Plugs, Short Throw Shifter, 4.10 Gears, Detroit Rocker Cams, FRPP Twin 62mm TB, Pypes LT, H-pipe, Flowmaster American Thunder Axlebacks, 93 Performance BAMA Tune, & lowered 1.5"
Old November 24th, 2011, 02:41 AM   #2
iPoopke Regular
2004 Mustang
iPAPKE will become famous soon enoughiPAPKE will become famous soon enough
Best way to clean plugs is just buy new ones. They really arent that expensive.
Old November 24th, 2011, 08:16 AM   #3
Huck's Avatar
2010 Mustang GT
Plugs are $70. That's expensive when they only have 14k miles
Sons of Liberty
Old November 29th, 2011, 03:18 PM   #4
wiggety wiggety whack!
brokenweasel's Avatar
brokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of light
$70? Do '05+ require iridium or platinum or some fancy plugs? Because I just put platinum's in mine for about $25. If you won't get new plugs, keep reading:
Do NOT use the wire wheel on your grinder!
You can TRY using electronic contact cleaner and wiping it off with a cloth, but make sure you have the correct gap as well. Should be able to get it at any parts store:
Originally Posted by dr.gonzo? View Post
Monkeys wear spandex with hotdog legs because race car.
Originally Posted by IndianaJoe View Post
yesterday was shorter because of the massive burnout i did, it spun the earth faster.
Threads Similar to: Best way to clean plugs
How To Clean Your IAC 01 Slate Stang V6 Mustangs 0 May 26th, 2011 08:25 PM
How often do I need to clean a new JLT CAI dachuckster 2005 - 2010 1 April 8th, 2011 03:52 AM
Clean Up? Befreder General Car Care & Detailing 6 February 18th, 2011 12:59 PM
Spark Plugs Gap for Colder Plugs Matt. V6 Mustangs 5 April 10th, 2010 11:48 AM
how do you clean IAC tacomatom 5.0 Mustangs 1 June 5th, 2008 03:04 AM
