2006 Mustang GT
General Brake Question
Why do brakes tighten up if you push the pedal when the car is off? Then when u turn it on they loosen back to normal.
I know that when you press the pedal, when its on, it pushes a piston on the master cylinder which compresses the brake fluid that pushes the piston that holds the brake pads onto the rotor. So how would they tighten up when the car is off?
![]() "Most of us played with tractors when we were little.
The lucky ones still do." Pype Bombs | Pypes O/R X Pipe | Hurst Short Throw | Bama Sct 93 |
Because the power brakes on today's cars are vacuum assisted units. This vacuum is only created with the engine running. No vacuum, no power brakes = harder pedal.
Threads Similar to: General Brake Question
| quick general question on brake pads | 0949er | 99-04 | 5 | December 30th, 2010 09:38 PM |
| general question | bigbadwollfff04 | 99-04 | 9 | June 9th, 2008 10:41 AM |
| General Question | My02GT | 99-04 | 23 | January 10th, 2008 05:25 PM |
| general question here!!! | CBSTANG | 99-04 | 7 | March 26th, 2007 10:55 PM |
| General question on brake system issues (bleeding/no pedal) | 95plainjane | General Tech | 3 | July 3rd, 2006 11:22 PM |
