How much nitrous can I spray
I have a 89 LX that I am currently spraying 75HP dry thru TB. This is a ZEX kit and it automatically adjusts fuel pressure through a fuel jet and vacum. My timing is set at 12 degrees right now. I want to bump up my shot up to 100 HP but according to the tuning sheet that came with the kit it says to retard my timing 2 degrees. And that would actually be retarding it to 8 degrees seeing they use the factory specs. I have a F303 cam and the car runs like absolute dog crap at anything under 12 degrees. As a matter of fact it most of the time stalls out at 10 degrees and when it does idle the whole motor shakes and it idles at around 400-500 RPMS. So can I spray 100shot at 12 degrees advanced safely and w/out detonation or not? My kit is a ZEX 5.0 dry kit part # 82015. I am also using a ZEX traction control window switch. I have it set up to spray from 3000-5500 and to start spraying in 3rd gear and on. I have been considering programming it to start spraying in 2nd gear but even with drag radials I think I will lose traction spraying in 2nd gear ecspecially since its going to start as soon as I hit second under WOT. But I really need to know about the safety of the 100 shot at 12 degrees timing. My engine is as follows:
302 stock block with new rings seals bearings(about 3000 miles on them now. my rods and stock pistons reconditioned) Edelbrock 5.0 performer intake manifold 75MM BBK TB 73MM C&L MAF 24# injectors 255LPH holley fuel pump BBK fuel pressure regulator MAC CAI F303 cam WC T5 tranny Aluminum drive shaft BBK full length headers 2 1/2 flowmaster exhaust |
unstoppable @ speed of light
Try it out and listen for detonation. Get some cooler-than-stock spark plugs and maybe even some 100 octane if you can. If you hear even the slightest detonation let off. It'll blow your engine in a heart beat.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end. |
#3 | |
'88 LX body '91 GT D/T
8.7 in the 1/8th
UR6IX is the NGK part number for our cars bro. Thats 2 ranges colder than stock. Thats what I'm puttin' in my car... Here's the web address and OE plug chart... http://www.ngksparkplugs.com/part_finder
Founder of the I don't like my shit centerd and want it back the way it was dammit! club www.myspace.com/evoalliance greatest band alive |
F-150 FX4
My tuner recommends no higher than 120shot on an internally sock mustang unless you want to hurt the life of your engine
1986 lx notch
9.98 @ 135
you won't have anyproblems spraying a 125 shot as long as you get some autolite 24s and you can run 12 degrees as long as you have 93 octane , btw i always replace the stock fuel pump when i spray my cars,. i've had 3 mustangs with the zex dry kit and haven't had any problems, fyi the zex dry kit will support a 200 shot ( they just don't advertise it ) youu have to buy different jets, i've personally sprayed a 175 with it and didn't have problems, and 2 of my buddies have used the 200 shot several times and have run in the 11s with only bolt on stangs
Threads Similar to: How much nitrous can I spray
| spray and plugs | mr. mopar | Drag | 2 | October 6th, 2007 11:50 AM |
| Rim spray? Need Help! | warrior86 | Visual | 1 | July 10th, 2007 11:55 AM |
| spray on cf!! | 232stang | The Clubhouse | 3 | May 7th, 2007 01:58 AM |
| Can I spray a dry shot before the MAF? | Robjta | General Tech | 10 | July 25th, 2006 11:18 PM |
| Got my spray hooked up. | red01 | General Tech | 5 | July 2nd, 2006 04:20 PM |
