after upr kmember install?
Old June 13th, 2006, 08:36 AM   #1
hrseply's Avatar
hrseply is on a distinguished road
installed a upr kmember kit w/coil overs recently. and after i installed it and had it aligned i have had this little problem. when i start to turn the wheel either to the left or the right it feels like it binds for a quick sec and then its ok? still using original rack and tie rods. is the problem there? i have seen the offset rack bushings and bump steer tie rods. is the the fix?
any help would be wonderful. thanks in advance!
93 lx coupe tweeked just a little!
http://www.cardomain.com/ride/2244066 lots of pics here!
Old June 13th, 2006, 11:38 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Find out where its binding. That is where you need to start. Check the steering shaft and make sure its not hitting the header or motor mount.
Old June 21st, 2006, 03:24 PM   #3
fakesaleen's Avatar
1988 lx t-top
fakesaleen is on a distinguished road
deffinitly the knuckle of the steering shaft have a friend turn the wheel lock to lock with the engin running while you watch it
http://i723.photobucket.com/albums/ww234/wendell1988/fakesaleen.jpg
Threads Similar to: after upr kmember install?
k/b install hellbred07 2005 - 2010 6 October 9th, 2007 10:46 AM
SCT 3 install ? yamahammer 2005 - 2010 3 September 21st, 2007 09:32 PM
tubular front kmember Invictus 99-04 3 June 23rd, 2007 08:50 AM
CAI install jabrennan V6 Mustangs 22 March 10th, 2007 03:30 AM
