caster/camber plates
Old June 7th, 2007, 03:37 PM   #1
ricks01's Avatar
ricks01 is on a distinguished road
Can a 99-04 Mustang lowered say around an inch be aligned without buying caster/camber plates?
Some say he keeps a picture of his wallet in his wallet..
Old June 7th, 2007, 06:45 PM   #2
Resident Bubblehead
00vabchgt's Avatar
00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough
you should be okay just lowering one inch, but i would probably go ahead and get the c/c plates anyway.
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old June 11th, 2007, 03:59 AM   #3
scubasteve041186's Avatar
2004 mustang 40th annv.
scubasteve041186 is on a distinguished road
Send a message via MSN to scubasteve041186
yeah you'll be fine
Old June 11th, 2007, 07:35 AM   #4
matrixpuba is on a distinguished road
Send a message via AIM to matrixpuba Send a message via MSN to matrixpuba Send a message via Yahoo to matrixpuba
each car is different. some will need it and others wont. just get some to be safe. if you wont run coilovers just get the 3 bolt design.
Old June 12th, 2007, 05:23 PM   #5
you shouldn't need c/c plates until you drop 1.5" or lower and after 1.5" I personally think you need something more drastic then c/c plates
Old June 13th, 2007, 01:58 PM   #6
ricks01's Avatar
Thanx for the help guys. I was thinking about going with Steeda Sport Springs. I think they're a 1 to 1 1/4 drop. I'll probably install them and if it needs them go from there.
Old June 27th, 2007, 01:47 PM   #7
Windveil Blues's Avatar
2006 Mustang GT
Windveil Blues is on a distinguished road
What would you consider 'more drastic?'
Thanks,
Jim
Old July 8th, 2007, 03:48 PM   #8
Nemisus's Avatar
Nemisus is on a distinguished road
Thanks,
Jim
Agreed! I'm now curious... as I've got a drop greater than 1.5.... using MM CC plates (4 bolt) I can not get the car aligned completely!
Toe and Camber are perfect... but Caster wont go below 5* positive.. and my CC plates are maxed!
Thanks
Nem
Old July 8th, 2007, 03:51 PM   #9
Resident Bubblehead
00vabchgt's Avatar
Thanks,
Jim
Thanks
Nem
you may want to add a bumpsteer kit like the Steeda one. i put it on when i lowered my car in May. it's not expensive and pretty easy to install.
Military Crew
MM1 (SS)
US Navy Veteran
Old July 11th, 2007, 09:30 PM   #10
oasr87 is on a distinguished road
just max out both casters and try to put them as equal as possible. if you cant put them equal put alitle more on the right tire. when i say a little more i mean like .2 degrees. you should be fine your tires wont wear out and your car will be stable azz fuck on high speeds...
Old July 18th, 2007, 04:45 AM   #11
and then of course adjust camber then toe
Old July 18th, 2007, 04:51 AM   #12
man i remember doing alignments for a living. good money in it
Old July 18th, 2007, 05:26 PM   #13
o sorry guys i haven't been on this side of things ( forums ) drastic is about 1.5-1.25" and lower but they obviously don't hurt to have (c/c) anyways look into a bumper steer kit or http://www.ashentep.com/webpages/alignment.htm try that out
Threads Similar to: caster/camber plates
camber caster plates Steves LX General Tech 2 February 20th, 2007 08:05 PM
Camber Caster Plates MustangMatt96GT 96-98 6 February 18th, 2007 10:04 AM
CASTER/CAMBER PLATES? PONYBOY14 General Tech 2 February 4th, 2007 05:24 AM
