having a problem depressing rear brake piston
i decided to change my brakes today and am having a problem pushing the piston on the rear calipers back in to make room for the new pads. on the front i just used a C-clamp but in the back nothing seems to work. ive tried using the clamp while opening the bleeder valve but that wouldn't work either. my car is a 99 V6. Does anybody have an idea what the problem could be.
the pistons have to be screwed in due to the caliper also fubctioning as a parking brake. they make a tool for this that you should be able to pick up at most auto parts stores or in a pinch, needle nose pliers or vice grips will work. you will see 2 notches in the piston, the tool goes into those and then the piston is screwed clockwise into the caliper and when you get it back far enough for the pads to fit over the rotor, one of the notches needs to be facing the bottom of the caliper. There is a little nipple on the pad that fits in there
1999 Ford Mustang V6
just be really careful with pliers as it is easy to gouge the caliper piston
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
ok so i just tried to screw the piston back in and it only worked on the passenger side so im thinking its the parking brake holding the driver side piston out. my parking brake is fully disengaged though so i have no idea how to fix it.
try putting some pressure inward on the piston while screwing it in. Sometimes they can be a real bear.
ok finnaly got it to work. thanks for the help
Threads Similar to: having a problem depressing rear brake piston
| brake caliper problem | burnout5.0 | 94-95 | 3 | October 4th, 2007 12:38 AM |
| Hey Brake Problem | Killax15 | 99-04 | 6 | August 23rd, 2007 12:45 PM |
| brake problem | spero | 99-04 | 2 | April 2nd, 2007 06:02 PM |
| baer brake kit problem | cristo | General Tech | 7 | March 10th, 2007 07:27 PM |
| '87 Corvette Brake Problem | Stan27 | All Other Vehicles | 2 | June 27th, 2006 03:56 AM |
