need more bite @ the track
Old June 19th, 2006, 04:21 PM   #1
the6ofthem is on a distinguished road
I’m running a 79 mustang with 26” Hoosiers, 31 spline Moser axle, 4.56 gear, spool, Lakewood traction action lift bars, comp engineering 50/50 rear shocks, aluminum driveshaft, T-5. The problem I am having right now I cannot get this thing to hook at the track. The slicks are only a couple months old, I have tried them at 8 pounds 10 pounds, they really push hard when trying to do a burn out in second gear so I’m thinking it should get out of the gate. I leave @ 4000 to 4500 and it’s like this thing is on a dirt road, when I go to second gear some wheel spin little sideways-ness 3rd is better 4th I can hear the slicks break. I have the moroso trick springs up front…….any thoughts . thanks
Old June 19th, 2006, 05:36 PM   #2
mdvaldosta's Avatar
11.47@120.58
How much power does the car have? What 60's and 330's are you running? What are you running for the front suspension? What's your burnout procedure?
Old June 19th, 2006, 05:49 PM   #3
the 60's were 1.60+- now they are up to 170-180's like i'm riding on street rubber. the front is Moroso front trick springs. roll into the water box quick turn over pull out the box go to second gear take her up 3500 dump the cluch take her on up to 5000, get smoke feel the car start to push take her to the light.
Old June 19th, 2006, 05:51 PM   #4
Drgnracin72's Avatar
try not launching it so high and hows the track prep. if the track isnt prepped its gonna suck all the time no matter what tire your running. have you played around with the suspension adjustments at all?
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old June 19th, 2006, 05:57 PM   #5
the track is pretty good to be honest, they sweep and spray it through the night, now i have been at other tracks that dont i understand that. i'm thinking i might need a taller tire but don't want to lose my gear in the trade. i can launch @ 3000 go to second get tire spin and the slick is coming loose at the big end of the track in 4th gear
Old June 19th, 2006, 06:03 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
What are all the details of the car? What engine, what rear upper and lower control arms, what is the full size of the rear tires, and any more info you can give. If you are losing tracking on the big end you are either making alot of horsepower, have too small of a tire or have a suspension that is way out of whack.
Old June 19th, 2006, 11:11 PM   #7
the engine is 351windsor, world product heads
150 NOS
T-5 transmission
Centerforce Dual Friction Clutch
South Side machine bar upper control arm
Lakewood Traction Action bars lower
hoosier 26x10.5
Air Bag in right side
Competition Engineering 50/50 shocks rear
Moroso Trick Springs front
OEM Struts front
Old June 20th, 2006, 01:02 AM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Do you have the front sway bar removed? Does the rear squat or lift when you launch the car? What is your pinion angle set at? Which bars do you have?
#1
or #2
You should have no problem hooking with what you have. If you have the bars pictured in #2 I'd be willing to bet your pinion angle is off.
Old June 20th, 2006, 10:48 AM   #9
I have set #1 the front sway bar has been removed, i'm running the lower control arm in the lowest position in the bracket. I had my wife try and run the cam corder, but i may as well asked the guard rail to do it she was filming the sky, the stands and not me on the track. I watch what i could see and it looks like the car leaves with a little lift but i can see the tail moving around
Old June 20th, 2006, 11:14 AM   #10
can you push down on the rear of the car or is it rock solid??
88 Mustang Coupe
www.rickscarcare.net
Old June 20th, 2006, 11:26 AM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You probably could make use out of a 28x10.5 tire but I believe there are issues elsewhere if the car is skating around that bad right now. In all honesty I would throw the moroso springs out and use stock springs and also put some adjustable struts in the front so you can tune the rise and fall of your front end. You should be able to launch that car at any rpm and get it to hook. I can't say much about the Lakewood bars you have because I've never used that picture #1 style of control arm. Is there any way you can adjust pinion angle by rotating the rear axle with your control arms?
Old June 20th, 2006, 11:44 AM   #12
Twist 2 Go ....there is some down push to the rear, but not to much nor i'm as strong as that gas burner either.
Darrell i was thinking on the 90/10 front struts first to see if that helps. I made a change to the rear with the air bag because a by stander at the track told me it was dipping real hard on the right side at launch and even pulling the left fron tire up, so in went the air bag
also by lowering the bar in the differant position on the brackett changes the pinion angle the lower setting is suppose to be for maxium traction
Old June 20th, 2006, 12:42 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Lowering the bar changes the intersection point. Having it in the lowest position in the rear should hit the tires the hardest. Pump some air in the air bag and see what happens.
Old June 20th, 2006, 01:04 PM   #14
Darrell thanks for the input, i'll get r done one way or another
Old April 14th, 2007, 10:48 PM   #15
rus
rus is on a distinguished road
I was wondering ,how do I weld in the southsides pictured in # 2.
Thanks
Rus
Old April 17th, 2007, 09:29 PM   #16
ujslost's Avatar
You need an angle finder 1st of all for #2 picture. They are the exact same thing as southside machine lift bars. Which is what I had on my 90 lx. They hook up good but will tear up the torque boxes quick if you dont weld them up. Do a search on lakewoods site they have a pdf file on the instructions for setting pinion angle and welding those up.
Threads Similar to: need more bite @ the track
Track MustangMatt96GT Drag 3 May 28th, 2007 09:37 PM
ran the track ttop5.0 Drag 8 March 7th, 2007 08:02 PM
my first day at the track 02steedagt 99-04 14 March 6th, 2007 08:47 AM
i might bite the bullet 232stang The Clubhouse 19 February 17th, 2007 03:24 AM
To The Track I Go. einod V6 Mustangs 15 August 18th, 2006 04:04 PM
