misfire....
Old June 19th, 2006, 09:56 PM   #1
stang fanatic's Avatar
stang fanatic is on a distinguished road
misfire....
Ok, after solving an electrical issue, the car has run fine. new wires, coil, cap and rotor, and aulite dp plugs...screwed up on a 3-4 upshift the other day and went 3-2 at 6k (imagine what second was... )...since then the car misfires after about 1k rpms up to around 4 or so that i know of. Plugs look super clean...whats failing? or what is the comp. telling it to do that it misfires?
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old June 19th, 2006, 10:55 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Is it throwing any codes?
Old June 20th, 2006, 03:15 AM   #3
GTXRacing is on a distinguished road
Dude... Didn't I tell you to get rid of that damn computer once already?!? LOL
All I need is a dime and my ears to add more Air/Fuel...oh yeah money too but you get my point LOL I'm playing man.
THE BEAST IS FOR SALE!!!
GTX RACING & PERFORMACE CLUB OF TEXAS
Meets and greets, drag racing and good eats, you know you want it.
GTX Racing
Tony P.
214-257-3635
http://www.moddedmustangs.com/forums...vehicle&CID=43
Old June 20th, 2006, 05:01 PM   #4
ck engine light isnt flashing, and code scanner never worked from day one on this car.
so throw the money... id convert in a heartbeat!
Old June 20th, 2006, 07:06 PM   #5
ck eng light won't flash on a 87 or set misfire dtcs. it's an obd1 car.
88 Mustang Coupe
www.rickscarcare.net
Old June 21st, 2006, 07:51 PM   #6
so any other ideas????
Old June 21st, 2006, 11:38 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Is the check engine light burned out? I've owned a few Mustangs that pulled codes but never had a check engine light on.
Old June 22nd, 2006, 08:28 PM   #8
ck engine light illuminates...previous reply stated obd1 systems do NOT illuminate the ck eng. lite for misfire codes...
Does anyone know much about the autolite double platinum plugs? are they any good?
Old June 22nd, 2006, 10:13 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I am well aware how an obd1 system functions. I wasn't asking if it had a misfire code. I was asking if it had ANY CODES. I had a bad mass air flow sensor cause a misfire in a 91 GT. The check engine light wasn't on but when I scanned it there was a code. So again, are there any codes?
Platinum plugs suck.
Old June 23rd, 2006, 10:08 AM   #10
scanner will not correct, and as previous attempts through the multimeter...will not indicate any codes at all...not even an all ok code
Old June 23rd, 2006, 10:08 AM   #11
ok...that was scanner will not connect.
Threads Similar to: misfire....
misfire at high rpm musclemike 5.0 Mustangs 2 September 12th, 2007 02:23 PM
cylinder 6 misfire Jucostud 96-98 4 May 10th, 2007 11:46 PM
Misfire Question oldernewbie 2005 - 2010 5 March 16th, 2007 04:36 AM
Misfire BAD Casper98GT Modular Mustangs 4 September 5th, 2006 07:24 PM
02 4.6 misfire...help me aaron175617 99-04 5 July 14th, 2006 09:25 PM
