1987 Mustang GT
Boost gauge question??
I ordered a paxton novi 1000 supercharger kit for my stang and i was looking to order a boost and a fuel pressure gauge that i was going to mount on a pillar pod. Now i know that the fuel pressure gauge has to be electrical if you want to mount it in the car but im seeing both mechanical and electrical boost gauges . Just curious which one to get and the advantages aor disadvantages of them
RLY SRS
You can run either a electrical or manual boost gauge...I run a manual myself...Its cheaper and does the same thing...You jsut ahve to route alittle hose in your car that is easy as pie...the electrical would have a sending unit and would only have wires going into the car...
1987 Mustang GT
do you run a fuel pressure gauge in your car? I have one on my fuel rail but i thought an in car one would be nice.
RLY SRS
I run and electric fuel pressure gauge in my car...thats the only way you can do it...The mechanical need ot be outside the cab...
F-150 FX4
Get a mechanical Boost Guage and an electrical fuel guage. Here is my setup:
![]() I am 100% happy with it and they read DEAD ON! |
1988 Mustang LX Turbo
im running a lab top and tells me everything, but i have a manual boost controller and FPR but i can adjust fuel from the computer
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
i have Auto Meter brand vacuum/boost guage and electrical fuel pressure guage. bought guages and pod for 300
Fuel psi gauge!!
you can run a mechanical gauge in the car, This is how they work, attach to your fuel psi regulator, then it goes to a preasure sensor on the firewall, the side that goes to your gauge needs to be filled with coolent. It's kind of a pain in the ass, but they work good!!!!
Threads Similar to: Boost gauge question??
| Where to hook boost gauge on paxton | nasty92LX | 5.0 Mustangs | 8 | July 31st, 2007 01:17 PM |
| Boost/Vacuum Gauge | troy1000rr | General Tech | 1 | April 21st, 2007 03:51 PM |
| Installing a boost gauge in an 03-04 cobra | vnmous | 99-04 | 1 | April 10th, 2007 02:04 AM |
| Vaccuum/Boost Gauge! | jerb43 | 96-98 | 1 | October 22nd, 2006 04:53 PM |
| Boost Gauge Not Working... Advice? | jerb43 | General Tech | 7 | September 20th, 2006 01:48 PM |
