1990 HATCH
12.56@118
throughin the car sideways
I have a panhard bar on the rear. When i pop the clutch and shift into second the car shoots to the right. People say shitty tires and i need to adjust the panhard bar. An expert opinion would be great. Thanks for looking!
1988 Mustang LX Turbo
it will always do that, its a thing called Torque and torque is good with a posi, making it fun to get sideways
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
Do you have any other mods to the rear end? If all you have is the bar, you will have to make other mods as well. Better shocks, replace the upper and lower control arms, as well the springs. The 86-93 was probably the worst handling Mustang ever built but you can correct this problem. Look at http://www.griggsracing.com/index.php http://www.maximummotorsports.com/ both companies make great products for your car. You have to know if you want to make a drag or road race car and then but the pieces that make it behave the way you want it to. Good luck.
I am not sure what phb you have, but this might help you determin if it needs to be adjusted.
http://www.griggsracing.com/pdfFiles/mpb1200.pdf Wouldn't subframe connecters help as well?
K&N fipk2 CAI, flowmaster 40 cat back, accufab 70mm tb/p, xcal2, 3.73 frpp gears, Steeda Tri-ax, Mach grill del. 255rwhp 295rwtq Needing more |
Threads Similar to: throughin the car sideways
| SIDEWAYS @ 150 mph in a KA-T powered 240sx vs a T/A on Spray | Mellon | Videos | 6 | December 20th, 2006 02:01 AM |
