General question on brake system issues (bleeding/no pedal)
Old July 3rd, 2006, 01:49 PM   #1
95plainjane is on a distinguished road
My 65 tbird. New MC and booster, lines, wheel cyclinders and calipers. ALl vacuum to booster is there and working fine. No leaks anywhere/ MC bench bleed the hell and back, lines bleed the hell and back. After all that I still have no pedal, it goes to the floor. I have brakes but the pedal does not stay up at all If I disconnect the vac to the booster the pedel stays up and goes down a little but of course I think have no power brakes. WIll it hurt the car if I drove with man brakes? I would think not.
Old July 3rd, 2006, 07:07 PM   #2
Bossman351 is on a distinguished road
Send a message via AIM to Bossman351
Have you tried to gravity bleed them? If not, what you do is take the bleeder valves out and fill the master cylinder with fluid then leave the cap off and let it sit for a while. the fluid should slowly push the air out as it sits so all you have to do is replace the bleeders and check for pedal. It may be necessary to manual bleed but you should only have to go thru about 1 or 2 cycles to get te rest of the air out.
Old July 3rd, 2006, 08:45 PM   #3
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
No Vacuum No problem. Just have a strong leg and alot of stamina!
Old July 3rd, 2006, 11:22 PM   #4
have you ck'd the pushrod length on the booster between the booster and the master cylinder??
88 Mustang Coupe
www.rickscarcare.net
Threads Similar to: General question on brake system issues (bleeding/no pedal)
Brake pedal gets stiff when A/C is on? throwedoff 99-04 1 June 22nd, 2007 10:51 PM
Brake pedal question... El_Cangri V6 Mustangs 16 May 18th, 2007 06:38 PM
general question here!!! CBSTANG 99-04 7 March 26th, 2007 10:55 PM
Brake Pedal Squeek 2000v6 V6 Mustangs 2 September 17th, 2006 07:40 PM
Brake pedal switch OTreborO 5.0 Mustangs 2 August 29th, 2006 05:47 PM
