lift off
Old July 3rd, 2006, 04:27 PM   #1
ttop5.0's Avatar
ttop5.0 is on a distinguished road
lift off
i have heard that by replacing certain suspension products you can lift the front end up after a hard launch, does anyone know how or what parts i could replace to do this????
Old July 3rd, 2006, 04:31 PM   #2
mdvaldosta's Avatar
11.47@120.58
It's all in the weight transfer, traction, and power. Get as much weight off the front end as you can, get some slicks, and some power.
Darrell's the wheelie man around these parts... check out some of his videos.
Old July 3rd, 2006, 06:59 PM   #3
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
yeap, the basics would be 90/10 lakewood struts, lakewood 50/50 shocks rear, eibach drag springs, upper and lower control arms. Then some et drags, 6000rpm lauches and pray lol. At least thats how i did it with only 285hp.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old July 3rd, 2006, 07:51 PM   #4
88 Mustang Coupe
www.rickscarcare.net
Old July 3rd, 2006, 08:48 PM   #5
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
Some of us don't have control arms in the back! We're still leaf springin it!
Old July 3rd, 2006, 11:23 PM   #6
ttop5.0's Avatar
so if i understand correctly, softer shocks in the rear and stiffer struts up front????
Old July 3rd, 2006, 11:27 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Re: lift off
Are you trying to attempt this with your car? What is all done to your car right now? The best suspension parts in the world won't do anything if you don't have the horsepower and drive train to go with it. The funny thing is you start out trying to do a wheelie and eventually you try to NOT do them which is quite a bit harder than doing them. Some light springs, 90/10 struts and no sway bar up front combined with a good rear suspension with tight shocks will help. Dialing in more negative pinion angle helps too but can be hard on parts. Put a blue bottle in it and it will help.
Threads Similar to: lift off
does your car have this much lift? MSO Videos 23 October 1st, 2007 12:13 AM
lift or ramps JASonic The Clubhouse 19 July 30th, 2007 01:29 AM
Max Lift javier351lx 5.0 Mustangs 2 July 11th, 2007 10:35 AM
Cam Lift cali 5.0 5.0 Mustangs 1 November 7th, 2006 01:23 PM
