2000 GT
slow
best suspension setup for handling
not for drag racing
what would be the best complete setup to maximize handling |
48.47@ 12.58
there are a lot of different set ups you can get...
here is a good one Poly Motor Mounts Tubular Subframe Connectors MM Strut Tower Brace MM 4 Point K-Member Brace Tubular Lower Control Arms Poly Front Sway Bar Bushings Poly Endlinks KYB GR-2 SHOCKS/STRUTS MM Castor Camber Plates Coilovers with 300 lb Springs Tubular A-Arms Flaming River Steering Shaft Panhard Bar Torque Arm Aluminum Rack Bushings
Threads Similar to: best suspension setup for handling
| best suspension setup? | madhandles97 | General Tech | 1 | October 26th, 2007 11:24 PM |
| suspension setup | travis_afx | 99-04 | 16 | September 11th, 2007 02:05 PM |
| Suspension Setup | Dawgs2099 | 99-04 | 7 | May 30th, 2007 10:45 PM |
| suspension setup | xzibit88 | General Tech | 9 | April 5th, 2007 10:01 PM |
| handling and suspension | terribleonexx88 | 5.0 Mustangs | 1 | October 15th, 2006 09:15 PM |
