2003 Mustang GT
12.61@108
Race Fuel for 100 Shot?
Is it safe to run a gallon or two of 100+ octane mixed with a couple gallons of 93 with a 100shot without putting in colder plugs? I just wanna make 2-3 runs to see if I can get it in ther 12's, which it should. Im doing a 75shot right now with the stock plugs and it runs perfect.
![]() *FOR SALE* Nitrous Express Kit, Summit O/R H-Pipe, Flowmaster American Thunder, BBK Subframe Connectors, Eibach Pro-Kit, Summit Rear Control Arms, 4.10 gears, SCT SF3, Nitto 555r's, and its an automatic. 240/277 N/A |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
do not run a 100 shot on your set up!!! you need to put in colder plugs. if something was to happen and the platinum tips blew off the plug, it can destroy the motor. not to mention the heat that bulids up with them plugs can make for a bad combination. but its your car, do what you want. i ran a 100 shot on my motor on pump gas without pulling any time from stock tune without a problem. i dont recommend doing it, but its possible.
2001 Mustang SVT Cobra
![]() iTrader: 1 reviews
I would not run the shot without retarding the timing and gaping colder plugs. PERIOD. To much risk taken.
Slow, really slow Cobra. Wanna see?![]() MM Cobra Club Member #81 "TAMPA BAY AREA CREW"
Are you still in the 13's with a 75 shot? If so, how close to 12 is it? I don't think bumping to 100 will help you that much into the 12's if not there already. Do you have DR's?
2003 Mustang GT
12.61@108
If its not safe without changing the plugs I wont do it, no big deal. Im at 13.3 with the 75shot. Probably coulda done a 13.2# if it wasnt hot and humid.
Do you have drags on?
2003 Mustang GT
12.61@108
no. 2.1 60fts. Pretty good track. I dont spray till the 60ft.
Well, that's a bit of a problem. You need or it would help if you had, some drags and start spraying the crap out of it at launch. Not worth it without the drags, but with them you hook pretty good.
The DRs alone should be enough to get you into 12s IMO
Threads Similar to: Race Fuel for 100 Shot?
| what is the best shot of n20? | 40thmustanggt | 99-04 | 10 | July 19th, 2007 09:32 AM |
| 75 shot | flattusmaximus78 | V6 Mustangs | 5 | June 27th, 2007 05:25 PM |
| Zex wet shot | 95wip | 5.0 Mustangs | 1 | May 2nd, 2007 02:30 PM |
| Stock fuel pump & 75 shot? | 5.slo | 5.0 Mustangs | 2 | January 9th, 2007 06:13 AM |
