cant find Hissing sound!!
Old July 27th, 2007, 07:10 PM   #1
|TH|BLaCkStAnG is on a distinguished road
Put on a off road x pipe. fit great. put some permatex sealer on the both outlets of the x pipe to the inlets of the stock "catback". I sounds like a well a cat hissing really loud during acceleration. I have so clue where its at. Sounds like its coming from the mufflers?
I was thinking about put seafoam in my car to clean it out a little and that would probably show my leak wouldnt it? thanks
Old July 28th, 2007, 11:06 PM   #2
460brevill's Avatar
460brevill will become famous soon enough460brevill will become famous soon enough
have someone squirt a little oil in intake while you watch exhaust.that will make it show up.
i sixing 200 six with 300 hp.
Old July 29th, 2007, 02:06 AM   #3
Moderator
You can also have a friend gently place a rag over one exhaust tip at a time and rev it up a little. No need to completely block the exit off, just enough to make the hiss louder so you can locate it.
Old July 29th, 2007, 02:20 AM   #4
i found the leak. Its in a totally different spot where i thought i was. Its coming from the header flange on the passenger side. I used the old gasket, it looked good, but i guess it rotted away or tore. So i have to go the the dealership to get one. also the x pipe seems to be flush against the header but is there a posibility that the "stops" on the bolts on the header flange are making it from not being completely tight?
Old July 29th, 2007, 02:23 AM   #5
Moderator
It's possible, especially if the seal is worn or cracked.
Threads Similar to: cant find Hissing sound!!
Can anyone find this for the V6? Vision.Pro Visual 5 April 20th, 2007 01:04 AM
Cant find oil for my 07 TDog 2005 - 2010 18 April 8th, 2007 04:37 PM
Where to find a 4.2 99v6stang V6 Mustangs 44 February 21st, 2007 01:28 AM
Hissing When Flooring.... slingblade05 5.0 Mustangs 4 September 20th, 2006 02:43 PM
some hissing notsoslo5.0 5.0 Mustangs 5 August 18th, 2006 02:42 AM
