I have a rear gear problem-please help
Old July 9th, 2006, 08:20 PM   #1
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
OK here's the deal- I have a 2003 GT and it is a daily driver. When I drive it to and from work ( about 8 miles), I don't have any problems. However, if I drive it a while ( 50+ miles or so) it begins to sound like the rear gears are binding when I turn at slow speeds. Has anyone had this problem or know what the problem might be??
Old July 9th, 2006, 09:35 PM   #2
rear diff clutches are grabbing. Replacing the gear oil and additive might help but Ford also has some new carbon-fiber diff clutches out to address this concern as well. If you're still under warranty, should be covered w/ no problem.
88 Mustang Coupe
www.rickscarcare.net
Old July 9th, 2006, 09:36 PM   #3
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
97Cobra will become famous soon enough
did you check the rear suspenshion?axel bearings etc etc. did you ever get new gears put in 3.73, 4.10s?????
Modifications and pics in my Garage...
Reps Appreciated!
Old July 9th, 2006, 09:41 PM   #4
MM's Mad Scientist
acmillr's Avatar
Slow Fella
I'm not under warranty anymore. I haven't opened up the rearend at all. It still has stock 3.26 gears with 39000 miles on them. How much money am I looking at to fix this problem if I have to go into the rearend? Also, is this a common problem with this model??
Old July 9th, 2006, 09:43 PM   #5
yes, it's fairly common although we replace them in the trucks and expeditions more frequently. the clutch kit is around $125 or so and installation takes about 1-2 hrs depending on your skill level.
88 Mustang Coupe
Old July 9th, 2006, 09:47 PM   #6
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
Twist 2 Go and his infinant fouintain of knowledge
Reps Appreciated!
Old July 9th, 2006, 10:12 PM   #7
MM's Mad Scientist
acmillr's Avatar
Slow Fella
What do I need to do to properly assess the situation, and where do I need to get the parts from? ( Ford dealer? )
Old July 10th, 2006, 02:08 PM   #8
parts are available at any Ford dealer. Here is a list of what is needed.
F5AZ-4947-BA 8.8" Axle Clutch Kit
XY-75W140-QL Rear Axle Lubricant need3
XL-3 Additive Friction Modifier need 2
F3TZ-4121-AA Metal Tag - 75W140
88 Mustang Coupe
Old July 12th, 2006, 08:44 AM   #9
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Thanks alot for your help.
Threads Similar to: I have a rear gear problem-please help
GEAR OIL LEAK IN REAR END!!! HELP chris03gt Modular Mustangs 5 July 9th, 2007 03:18 AM
Gear install problem DCstangGT 99-04 23 June 17th, 2007 05:48 PM
rear end gear ratio G.T. Rags 96-98 37 April 24th, 2007 12:31 AM
Help Me With My Gear Problem Please Steeda325 V6 Mustangs 11 October 26th, 2006 10:31 AM
Rear gear size charliemopps24 General Tech 4 May 30th, 2006 06:41 PM
