Parts cleaning for engine rebuild
I think the title is pretty self explanatory, but here it goes anyways. . .
I'm rebuilding my '96 3.8 to replace a blown head gasket. The problem is, theres burnt on coolant pretty much everywhere. Mainly I'm worried about the interior of the engine, but I'd really like to clean up the outside as well. I'd like to pretty much shine up the entire head on both sides, and the lower intake manifold. Is there any way I can clean the intake, exhaust, and coolant passageways? I've wot some EngineBrite engine cleaner, and some carb cleaner for the hard to get stuff, and I've been scrubbin away with a tooth brush for like 3 days, ant what I can reach looks ok, but I need a way to like de-grease the entire head. Is there a solution or something that i can dip it in to clean the entire part? |
1988 Mustang LX Turbo
Well you can either do like this,
get some can's of brake part's cleaner, they work fairly well use a sand blaster, and blast the whole head and area's needed and if your using the parts cleaner, get a nice thick metal wire brush
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
2001 YUGO GT
You can take Tide and water mix it into a paste, hit it with a good parts cleaning brush, that take the parts to your local car wash and pressure wash them off dry then use a blow dryer to ensure all the moisture removed, give iron parts a light coat of oil and be done with it. Also now is a good time to paint, if you haven't oiled the parts.
Threads Similar to: Parts cleaning for engine rebuild
| Engine Cleaning? | Snipe061 | Visual | 14 | September 22nd, 2007 12:04 PM |
| Parts cleaning for engine rebuild | Buttaz | V6 Mustangs | 8 | August 5th, 2007 11:02 PM |
| Engine Cleaning | tnknepp | Classic Mustangs | 4 | July 23rd, 2007 06:48 PM |
| Cleaning engine | MustanG_guy17 | 99-04 | 14 | April 20th, 2007 09:22 PM |
| Cleaning Engine | themav46 | V6 Mustangs | 15 | October 9th, 2006 07:23 AM |
