Anderson power pipe question
Old August 5th, 2007, 09:35 PM   #1
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
Do the power pipes really make a difference? I have a paxton blower thats only pushing 5-6 psi, if i put one of those on will i gain any boost?
Old August 6th, 2007, 02:53 AM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
the power pipes do make an quite noticable difference,
but it wont rasie your boost unless you switch for a smaller pulley
Old August 7th, 2007, 12:35 AM   #3
jam77's Avatar
1987 Mustang GT
so would one of these have any positive effects or am i just wasting money?
Old August 7th, 2007, 12:51 AM   #4
sonicblue's Avatar
1990 GT
sonicblue is on a distinguished road
you might see one more pound of boost. you will see a difference and its worth the money imo
getting all fixed up for next season
2004 mustang gt 520rwhp, 491 trq sold
Old August 7th, 2007, 05:43 PM   #5
RLY SRS
ChrisJ's Avatar
ChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud of
iTrader: 9 reviews
I saw 2#'s with my boost pipe...
It helps alot...But you need to have it tweaked in the tune...
Facebook
Google+
Threads Similar to: Anderson power pipe question
Anderson Power Pipe stangliter04 Parts 10 February 2nd, 2010 09:37 PM
Power Pipe MATT02GT 99-04 20 July 16th, 2007 11:14 AM
x pipe installed, no more power flyingbullitt 99-04 23 July 11th, 2007 11:19 PM
Anderson PMS shadowgames81 5.0 Mustangs 4 July 6th, 2007 07:39 PM
Power pipe Pony_with_an_attitude 5.0 Mustangs 4 March 24th, 2007 02:58 AM
