#41 |
tttttttttttttttttt
#43 | |
#44 |
I still have been having problems with tuning but they did do a pull to 4,000rpm. On 8psi, 252hp/442tq @3,000. 361hp/471tq @ 4,000rpm.
Kenne Bell 2.6, 8rib, 3.5" blower pulley, JLT 03 cobra Intake, Lightning MAF, 60lb injectors, 255lph intank pump, Kenne bell boost-a-pump, 9:1 compression, Ported PI Heads, XE274 comp cams, Diablosport chip.
1997 GT 1989 LX ~Dangerously Quick/Needs Battery
#45 |
Just got it tuned today, 487hp/482tq on 9psi
#46 |
02 mustang gt
6.92 @ 99 mph 1/8th
stock long block 80000 miles
vortech v-1 s trim 10# snow performance water/meth injection pro products 75mm Tb/plenum Typhoon intake manifold bbk shortie hearders O/r h pipe 40 series flowmaters tuned at 11.2 a/f ration and 15 degrees of timing 347 hp/ 342 tq on a mustang dynometer i just got a wide band so im going to the track tomorrow and going to play with the a/f and timing to get more power out of it.... |
#47 |
Vortech V2 SQ-Trim @ 8-9 #s
366/382 38# Injectors Ford GT supercar pump MGW STS Everything else is stock minus a couple gauges. Planning on a o/r MAC Prochamber next month and possibly 3.73s. We'll see how the funding goes. A couple pics for your visual pleasure. ![]()
#48 |
UPDATE
Mike@Powerhouse411 just tuned the car at 400/380 @7psi on mustang dyno Last edited by stroked87; June 30th, 2009 at 08:42 PM. |
#49 |
quick dyno pick at powerhouse411
http://www.youtube.com/watch?v=OOQAqDXK2_w |
#50 |
Look Ma! My First Post!
97 Cobra
10's
-Stock displacement
-Ported “B” heads with mach 1 cams -03 tb -Screamin demon coil packs and live wires -Full 8 rib conversion with innovators west 10% over drive dampener - F1A Procharger, Anderson power pipe, 3 core sheet metal race intercooler -60 lbs injectors, 255 in tank, 255 inline -BBK long tubes, high flow cats in x pipe (new), dynomax bullet mufflers dumped -Manual tensioner -Tial 55 mm bov -Sct 2400 maf with Diablo mafia, run blow through -Sct chip in now, also have sct livewire (handheld) and sct proracer package (full tuning capability) -Billet oil pump -Canton 8qt road race oil pump Transmission -03 cobra t56 -Liberty gears input shaft -03 cobra drive shaft -Pro 5.0 shifter with kick back plate. Square plate to bring shifter back closer to driver -Centerforce DFX clutch and pressure plate -Fidanza flywheel Rear end -Factory 8.8 housing -Mosier 31 spline axles and studs -Detroit mechanical locker -C-Clip elimators -3:73 gears 580rwhp 570rwtq @15psi....intake is choking the car Once the Hogan sheet metal intake goes on I'll turn up the boost and should see well over 620rwhp Last edited by Dubz; July 9th, 2009 at 09:59 AM. |
#51 |
1994 Mustang 5.0
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
Blower setup in my Sig.
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
#52 |
332 cubic inch short block, AFM B-451 cam, Edelbrock Victor Jr heads, Vortech intake, Vortech SQ S-trim with 2.95 pulley. Makes 540 hp and 560 tq @ rear wheels on pump gas through hi-flow converters. All in a stock appearing 95 Cobra.
Threads Similar to: Post your blower setup!
| Blower cam on N/A | TheBusher | 99-04 | 11 | August 31st, 2007 05:27 PM |
| Blower | Mustang RacR94 | V6 Mustangs | 4 | August 28th, 2007 11:53 AM |
| BIG blower | BWAL | 5.0 Mustangs | 17 | June 6th, 2007 07:32 PM |
| N/A Cam and Blower Cam ??? | StuTheMusicEngineer | 99-04 | 1 | March 3rd, 2007 05:35 AM |
| which blower | 342stroker | General Tech | 2 | February 14th, 2007 07:20 AM |
