Which centri?
Old August 13th, 2007, 02:22 AM   #1
sorrowfulkiller is on a distinguished road
Which centri?
I'm wondering what kind of centrifugal supercharger to get, I've got a 96 GT that is well maintained. I want to get roughly 500 hp out of it eventually. I'll be adding water meth injection after the supercharger is in too. I want a car that is fully streetable yet also fun at the track.
Any suggestions?
Old August 13th, 2007, 02:58 AM   #2
matrixpuba is on a distinguished road
Send a message via AIM to matrixpuba Send a message via MSN to matrixpuba Send a message via Yahoo to matrixpuba
with 500rwhp you will need a built bottom end. you dont have to run a meth kit. i say go with a procharger d-1SC. it is plenty for what you need.
Old August 13th, 2007, 03:03 AM   #3
I know I'll need a built bottom end... btw with a tune how much can the hypereutectic stuff take?
I want to run a meth kit because I want to run more aggresive timing than just a normal tune
and actually I would much rather have a chemical type cooling than an intercooler... stealth shit is more fun xD
Old August 13th, 2007, 07:28 AM   #4
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
well if you dont want an intercoller showing, you can always run an aftercooler. i also recommend procharger. the stock motors are hypereutectic stock and will handle around the 430-450rwhp range.
Old August 13th, 2007, 09:24 AM   #5
wow, I didnt think they could handle that much!
Old August 13th, 2007, 09:44 AM   #6
now what about tuning? what options do I have?
Old August 13th, 2007, 10:06 AM   #7
it is up to where you get it tuned at. some shops use diablo others use sct. if you look at the more known shops they will run sct so if you go that route you will have to either have a chip burned or a programmer. either way your tuner will point you in the right direction.
Old August 14th, 2007, 09:18 AM   #8
The Mean Green
MATT02GT's Avatar
MATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really nice
Procharger
Bolt on list in Garage..
Old August 17th, 2007, 07:03 PM   #9
alright, procharger it is... I'll be pretty much making my own setup. I've decided on the tuning issue too...
I've decided that I'll be using an extra injector controller, keeping the stock injectors, and will also be buying the sniper special forces software to make changes to the spark map and tranny shift points and firmness,
and unlike other people who've done extra injector setups, I'll be using the injectors straight into the manifold via a plenum/manifold spacer about 3/4 to 1 inch wide. I'll be using two injectors on either side, one closer to the front of the car and one closer to the rear. at a maximum of a 45 degree angle bit probably less than that.... hopefully a 30 degree agle. I've got a friend used used a similar setup on the 2.2L chevy ecotec engine directly into the manifold and is making close to 600 hp, so its a proven technology... not some bullshit excuse.
Reasoning behind this setup is that I want to be able to control my fuel easily if I go out to a track and change a pulley. or if I go on a trip to lower altitudes... don't want to fuck anything up.
Old August 17th, 2007, 07:06 PM   #10
Do the 96 mustangs use high impedence injectors or low though?
Old August 17th, 2007, 11:02 PM   #11
sonicblue's Avatar
1990 GT
sonicblue is on a distinguished road
"and actually I would much rather have a chemical type cooling than an intercooler... stealth shit is more fun xD"[/quote]
there is nothing stealth about the prochargers....they are loud as fuck
getting all fixed up for next season
2004 mustang gt 520rwhp, 491 trq sold
Old August 20th, 2007, 12:45 AM   #12
there is nothing stealth about the prochargers....they are loud as fuck[/quote]
How so, like whine sound or what?
and does anyone know the impendence of the injectors?
Old August 20th, 2007, 03:06 AM   #13
im not sure about the injectors. i can say that the procharger on my car was crazy loud at idle, normal driving and very loud at wot.
Old August 22nd, 2007, 11:20 PM   #14
9Sec03Cobra is on a distinguished road
They are high impedance injectors
2003 Cobra
9.5 @ 146 on radials
Just a few bolt ons with a good tune
04 Mach1
9.78 @ 138.9
Threads Similar to: Which centri?
opinions on centri type blowers?? Invictus 99-04 14 March 26th, 2007 01:16 PM
Anyone running4:10 with a centri blower? EXGTO Modular Mustangs 3 January 15th, 2007 06:16 PM
