RLY SRS
Timing Adjust For Nitrous
I have a Compu Car Wet System...I have already bought the fuel pressure safety switch, MSD Digital Window Switch (8969), Purge, and the Steeda Timing Adjuster (I am still waiting on a deal on a bottle warmer and blow down tube)...
How much should I retard it for a 90 shot? My current mods are in my garage... Any help would be greatly appreciated... Chris |
i think something like 2-3 degrees but dont quote me on that! ill let the n2o experts chime in on this en
#3 | |
RLY SRS
Hell Im only running the N2O for about a month or so then I go to the desert...Then come back from the desert my car goes to MPH for a mongoose kit, long tubes, and a nice tune... So im just working on the safe side... |
3 degrees is fine. The rule is 2 degress for every 50 and that is conservative. I've sprayed 100 over and over again without pulling any time out. 100 or less is just tickling the engine.
#5 | |
RLY SRS
Thanks Everyone... |
You will be fine. I spray 150 on 4* .
I spray 200 on 6 degrees using a progressive controller.
#8 | |
RLY SRS
That makes everything alot better for me... Thanks Peeps... |
Threads Similar to: Timing Adjust For Nitrous
| What do I adjust the timing on crank&cam??? | JONJON | 5.0 Mustangs | 10 | October 17th, 2007 07:53 PM |
| Nitrous and what should I set my timing at | Steves LX | General Tech | 2 | September 28th, 2007 06:51 PM |
| CAn you adjust the gas pedal? | 03_StangGuy | 99-04 | 17 | September 4th, 2007 12:14 AM |
| Retard Timing for Nitrous | marcfiebka | 99-04 | 8 | July 10th, 2007 10:30 PM |
| Nitrous Timing | zerofx150 | 99-04 | 5 | April 26th, 2007 10:11 PM |
