Gear change for nitrous?
Old August 22nd, 2007, 08:03 PM   #1
rockinjester is on a distinguished road
I have an 82 hatch that weights 3010 race ready. It runs mid 9.8's to low 9.9's depending on track situations. I have been running mostl 1/8 mile low 6.20's to mid 6.30's but an occasional, 1/4 { NMCA, NMRA, Ect...} Problem is. My peak HP is @ 6850. I shift @ 6500 and go thru the traps @ 7300-7400 in the 1/4. I am adding a nx hitman plate system with 200 shot single stage. What would be an ideal gear ratio to keep the rmp no higher than 7000-max 7200?
Current set up is. 418w, c-4, 5500 converter, 4.10 ratio, 28x10.5x15
File Type: jpg pinks_all_out_1st_time_trial_launch_122.jpg (176.5 KB, 133 views)
Old August 22nd, 2007, 08:18 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
darrell will be the guy you want to talk to. if it was me i would look into a set of 3.55's
Old August 23rd, 2007, 10:24 PM   #3
I thought about the 3.55's. I think they would work great @ the big end in the 1/4 but not in the 1/8. I probably wont spray off the line or thru 2nd. But I might do it once all out tho see what It will do. But mainly plan on high gear use, for a couple events.
Threads Similar to: Gear change for nitrous?
Gear oil Change question?? Cantbeatblack 99-04 3 September 20th, 2007 01:00 PM
How do you change out the speedo gear? YNOT 5.0 Mustangs 3 May 2nd, 2007 09:43 AM
4.30 Gear to much gear for street use/daily driver? Bigb2000GT 99-04 10 March 28th, 2007 05:22 PM
3:73 Gear change Draftmaster Modular Mustangs 7 March 25th, 2007 07:14 PM
