DTC Front 2 Oxygen Sensors- help please.
LinkBack (1) Thread Tools
Old July 20th, 2006, 10:29 AM   1 links from elsewhere to this Post. Click to view. #1
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) &
P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
were thrown in my car this morning. The sensors ar eplugged into the bungs on the collector pipe of my long tubes, and have not thrown a code sense installation last winter. I got on it hard and rode it to redline at WOT for 2 gears on my way to the dentist this morning. I cleared the codes with my xcal 2, but in case they come back- any suggestions?
I have the oxygen sensor extender harness from jegs. It has a high-temp coating for the wires in a jacket similar to that of the EGR pipe.
I have bosch oxygen sensors for the front.
They are a screw in style and we used tape on the threads to ensure tight fit.
What would throw these two codes and no others? 2 O2 sensors don't go out at the same time do they?
ModdedAutos
1999 Mustang V6
Old July 21st, 2006, 09:10 AM   #2
14.79 @ 92.15
Bump, Both codes came back after starting the car 2x. Any help appreciated.
ModdedAutos
1999 Mustang V6
Old July 22nd, 2006, 10:55 PM   #3
14.79 @ 92.15
Here is what I found:
Code:
HEATED OXYGEN SENSOR (HO2S) MONITOR - HO2S SIGNAL CIRCUIT MALFUNCTION
Diagnostic Trouble Code Description Possible Causes
P0135 -HO2S Sensor Heater Circuit Malfunction (HO2S-11) During testing, the HO2S heaters are checked for opens/shorts and excessive current draw. The code will set when current draw exceeds a maximum calibrated limit or falls below a minimum calibrated limit and/or an open or short is detected. ·Blown fuse
·Short to VPWR in harness or HO2S
·Water in harness connector
·Open VPWR or GND circuit
·Low battery voltage
·Poor electrical connections from PCM to HO2S sensor
·HO2S heater
·PCM
ModdedAutos
1999 Mustang V6
Old July 22nd, 2006, 11:19 PM   #4
14.79 @ 92.15
Found the fix. I was unplugging and messing with the oxygen sensors when I noticed that the plastic plug from the sensor to the extender harness on both sides had melted to the long tubes and shorted the wires. I guess I need new front O2 sensors and extender harness now.
ModdedAutos
1999 Mustang V6
Old July 22nd, 2006, 11:37 PM   #5
mdvaldosta's Avatar
11.47@120.58
Glad we could help
Old July 22nd, 2006, 11:44 PM   #6
14.79 @ 92.15
Well, I pulled the sensor harness away from the headers and cleared the ecu and started it about 10x and drove it for a half hour and it is fine! I just need to tape up the melted plug area with electrical tape then a high temp tape and I am done! Thanks for the help guys :wink
ModdedAutos
1999 Mustang V6
Old July 22nd, 2006, 11:50 PM   #7
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
Dumbass!
Old July 23rd, 2006, 12:02 AM   #8
14.79 @ 92.15
Dumbass!
The harness is wrapped in the "EGR wrap stuff" The high temp stuff wraps the O2 extender harness, but it slipped to the plastic plug and melted, making the wire temps too hot. Honest mistake- could happen to anyone
ModdedAutos
1999 Mustang V6
Old July 23rd, 2006, 12:04 AM   #9
turp's Avatar
3 feet...
Dumbass!
Yes but you get extra shithead points for having "the perfect answer" to everyones questions but breaking your own ride! Ha ha ha ha Fuka
Old July 23rd, 2006, 12:05 AM   #10
14.79 @ 92.15
Dumbass!
Haha, I have the perfect answer because I broke my ride searching for my own answer to the same question a couple months ago!
ModdedAutos
1999 Mustang V6
Old July 23rd, 2006, 12:06 AM   #11
turp's Avatar
3 feet...
Which leads me to my previous statement... Dumbass!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/general-tech/3229-dtc-front-2-oxygen-sensors-help-please.html
Live Mobile Search This thread Refback February 20th, 2012 05:26 PM
Threads Similar to: DTC Front 2 Oxygen Sensors- help please.
SES Light Back on after replacing front o2 Sensors. mixedbreed02gt 99-04 3 October 24th, 2007 08:02 PM
Replacing oxygen sensor for 96 ford mustang mylist Modular Mustangs 4 October 11th, 2007 11:04 PM
Oxygen sensor question MnrlGry01gt 99-04 3 June 2nd, 2007 01:17 PM
Oxygen sensors ga_skeeter1980 Modular Mustangs 0 December 4th, 2006 07:30 PM
