2002 Mustang GT rear disc brake Question
Old July 21st, 2006, 02:10 PM   #1
lucidsoul5 is on a distinguished road
I have a 2002 Mustang GT and I am attempting to change the rear disc brakes. I undid the caliper bolt and slid the caliper upright to attempt to change the pads but the piston is still compressed too tight to let me get the pads out. Now I read that there is a tool to reset the piston and I assume that I need to reset the piston before I attempt to remove the old pads. Please correct me if I'm wrong. What I need to know is where do I use this special piston resetting tool is it in front of me or behind the rotor? I am still used to using a clamp so this is different. Also what is the tool called so I know what to ask for?
Old July 21st, 2006, 02:12 PM   #2
mdvaldosta's Avatar
11.47@120.58
It's like a little cube with notches on it, you put it on a ratchet and twist the caliper piston back in. You get it at auto parts stores, it's pretty cheap.
Old July 22nd, 2006, 01:24 PM   #3
I looked up the tool your talking about. One more question. Where is the notch to wind back the piston on the caliper. Im sure Ill see it when I take off the tire again but Id rather have an idea where to look.
Old July 23rd, 2006, 12:47 PM   #4
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
the notches you turn are on the caliper piston behind the brake pad, also make sure you don't have your e-brake engaged.
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old July 24th, 2006, 04:24 PM   #5
Thank you guys for your help. I got the tool and changed my brakes. Saving me a nice amount of cash. Without people like you helping the rest of us we would be forced to overpay for easy maintenance.
Old July 24th, 2006, 04:27 PM   #6
Ohh one more thing. It was kind of a pain in the ass, winding the piston back. But still worth it.
Old July 24th, 2006, 05:21 PM   #7
yeah i don't have the tool, but use a set of flat tipped pliers to do the same thing, but you have to be really careful when doing it as you found out there is a little resistence there so it is easy to mare the caliper piston surface.
Old September 1st, 2010, 07:17 PM   #8
sikorski04 is on a distinguished road
Caliper tool
OTC/Disc brake piston tool (4589) | Brake Tool | AutoZone.com
Buy the tool displayed above. Though none of the surfaces will fit, a few modifications will help the problem.
On the surface with four small pins, cut two DIAGONAL pins with a hack saw, and file down if necessary. This will provide enough distance to smoothing grasp the slots of the piston.
The slots are located behind the rotor. You will have to take off the caliper, and the you will see the piston. Use this tool to compress it. Very easy.
Old September 3rd, 2010, 12:29 AM   #9
94 v6 mustang
Puffy93 is on a distinguished road
Also if you have abs you need to crack the bleeder screw before forcing the piston back. If you don't you run the Risk of ruining a abs unit which is probably around $2500
Threads Similar to: 2002 Mustang GT rear disc brake Question
Disc Brake Conversion wonders_of_a_V8 Classic Mustangs 6 January 20th, 2009 10:16 AM
Disc Brake Conversion gotboost562 5.0 Mustangs 8 November 10th, 2007 06:38 PM
90 rear disc brake conversion 7-up man 5.0 Mustangs 8 July 1st, 2007 03:56 PM
2002-front disc brakes-standard 6 cyl mustang Skee General Tech 0 October 21st, 2006 11:28 PM
Got another disc brake problem. lucidsoul5 General Tech 0 July 24th, 2006 11:46 PM
