Drivers window motor
Old September 4th, 2007, 09:26 PM   #1
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
How do I get to it to pull it out and cnange it. Window is down btw
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old September 4th, 2007, 09:43 PM   #2
thetrooper31 will become famous soon enough
Send a message via AIM to thetrooper31
take the panel off?
[SIZE=5][COLOR=Yellow][/COLOR][/SIZE][COLOR=green]
[/COLOR]
Old September 4th, 2007, 09:45 PM   #3
02ponypackage's Avatar
02ponypackage is on a distinguished road
will it not go up ? sometimes in the heat when my car is seating and the Dside window goes all the way down it wont come up...so u just gota give it a nice hit in the lil door pocket area below lol then keep ur finger on the up button...that works for me...but u might have a whole diff. problem...give it a try neways....gota get a nice hit tho
just a V6 with a bad belt slip under the hood
Old September 4th, 2007, 09:47 PM   #4
2000 V6
Originally Posted by thetrooper31
take the panel off?
I meant after that...and yeah Ive been hitting the door panel for a couple weeks. that window isnt coming up this time tho
2000 V6 vert
Old September 4th, 2007, 09:47 PM   #5
thats probably because hes taken enough of ur beatings..and found a new man lol
Old September 4th, 2007, 10:01 PM   #6
2000 V6
Yeah the motor threw in the towell on me
2000 V6 vert
Old September 4th, 2007, 11:16 PM   #7
fastpony's Avatar
1998 ford mustang gtclone
fastpony is on a distinguished road
Send a message via AIM to fastpony
check the switches first take them out and clean the connectors thats is what happened to mine. if the window goes up at all then its may not be the motor. take the switch panel and unplug the control switch it should just pop out and take the plastic casing off of the small switch and clean the connecting points on the switch and it sould work.
Old September 4th, 2007, 11:29 PM   #8
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
you might wana check your wires..it may not be the window...same thing happen to me...window stuck down then it randomly in 5hrs went up wen i check on it agian...lose wiring...
before you spend the $90 on the motor
[SIGPIC][/SIGPIC]
Acmillr loves me
Old September 5th, 2007, 01:41 AM   #9
GatoStang's Avatar
2002 V6 Mustang
GatoStang is an unknown quantity at this point
take the panel off?
did you hit it while holding the up button???
thats what i did when i had the same problem also I kicked my door.
Ghost Ride The Whip!!!
Old September 9th, 2007, 10:20 PM   #10
2000 V6
Hmm...if my lights kinda dim when I hit the switch that should mean the power is going somewhere right? ill try cleaning the connectors, but with my luck ill prolly be replacing the motor
2000 V6 vert
Old September 14th, 2007, 05:10 PM   #11
2000 V6
Alright so I got the whole motor/actuator out of a 97 can I pull mine out of the door and stuff this one in?
2000 V6 vert
Old September 14th, 2007, 05:37 PM   #12
2000 V6
and how so...my window is stuck down
2000 V6 vert
Old September 14th, 2007, 08:05 PM   #13
2000 V6
Ok so I swapped em and it seems to work, but now the window like gets stuck on the way down
2000 V6 vert
Old September 15th, 2007, 01:49 AM   #14
Rebel Of The Sacred Heart
travis_afx's Avatar
'02 GT
travis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of light
if it goes up and down fine until it reaches that peticular spot then somthing has to be binding or getting in the way of the track when it hits that spot.
your just gonna have to get a flash light and roll it up and down while looking inside the door to see what its catching on and move it and it should be fine.
Threads Similar to: Drivers window motor
drivers window won't stop on auto acobraman 96-98 10 September 27th, 2007 08:38 AM
transmission slipping/hunting? Drivers side power window? jasburrito 94-95 4 August 27th, 2007 02:39 PM
drivers side window regulator removal? jrfan4life 99-04 3 July 29th, 2007 12:50 PM
Drivers side window won't go down. 8A_Honda V6 Mustangs 18 July 19th, 2007 12:41 AM
drivers side window firefly1241 5.0 Mustangs 12 December 5th, 2006 01:33 PM
