Oil pump and oil...
Two questions actually...
Will the stock oil pump on a '98 GT be able to handle pumping oil back to my remote turbo? The turbo is located where the driver side muffler used to be. Second, what is a good oil to use? I hear a fully synthetic is really good on turbos.
Parting out 2003 SVT Cobra Air/Fuel http://www.moddedmustangs.com/forums...003-cobra.html Engine http://www.moddedmustangs.com/forums...003-cobra.html |
1988 Mustang LX Turbo
the stock oil pump should work fine
Synthetic is NOT a good oil for a turbo, there was a theory behind it that i read somewhere some good Castrol 5w-20 would do fine
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
I was looking into that Royal Purple stuff. I heard it was good sh*t. I don't know if it is turbo friendly though.But I'd have to order it every time I needed to change oil, so going with that Castrol would probably be my best bet huh?
Most guys on TM are running it, but Royal Purple is just as good
as long as its not synthetic, you'll be replacing bearings in no time with synthetic
Threads Similar to: Oil pump and oil...
| 2007 Pump Gas Drags 32 of the fastest pump gas cars | Mellon | Videos | 7 | June 14th, 2008 12:08 PM |
| need new P.S Pump | El_Cangri | V6 Mustangs | 22 | August 8th, 2007 04:05 PM |
| Mechanical pump, or existing in-tank pump? | shnipplelicken | 5.0 Mustangs | 7 | July 11th, 2007 11:47 PM |
| svt focus pump vs. ford GT pump | undomesticfire | 99-04 | 3 | May 15th, 2007 07:10 PM |
| A1000 Pump With 255lph In-Tank Pump ? | 92lx5oh | 5.0 Mustangs | 11 | March 18th, 2007 08:51 PM |
