Mid-Mount Plates
Old July 25th, 2006, 12:27 AM   #1
loudenough is on a distinguished road
Send a message via AIM to loudenough Send a message via MSN to loudenough
Mid-Mount Plates
I almost always do CE front mount plates and all my cars and trucks but anyone ever use a mid-mount plate?I am wanting to know if it does make a differance if you use all solid mounting(Engine & Trans)
Old July 25th, 2006, 12:39 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
If you put a front motor plate on you should be putting a mid plate on as well.
Old July 25th, 2006, 06:29 AM   #3
I agree. An engine plate needs a mid-plate and a limiter as well as a trans mount to support the weight of the tailshaft
88 Mustang Coupe
www.rickscarcare.net
Old July 25th, 2006, 10:53 AM   #4
are you both trying to say do it for the twist? if so I don`t think it would be worth it for me my tranny is part of the truck and won`t move even with a 3000hp motor with torque to match.I have it sollid mounted in two spots(front and back of trans) plus I have a front mount plate( yes a limiter too) and I have a engine cradle that is solid to the frame and motor.If it is only for flex I have none and it would be only a few inches(maybe 4 max) between the motor and trans that is not solid mounted.If other reason you say that I need or should use one please fill me in why.Thanks
Old July 25th, 2006, 01:26 PM   #5
A midplate isn't used for flex. It's used primarily as a support to remove some of the weight from the trans case. Cars that use just a front plate and a rear trans mount tend to crack the trans case due to flexing.
88 Mustang Coupe
Old July 27th, 2006, 01:23 AM   #6
Thanks a ton,thats what I was thinking and I guess I`m covered as my rear solid mounts are real close to the trans
Threads Similar to: Mid-Mount Plates
Where it mount switches 06VistaBlueGT 2005 - 2010 24 October 2nd, 2007 03:01 PM
Where to mount the NOS tank? Rutcutter 5.0 Mustangs 7 July 30th, 2007 07:38 AM
Transmission mount ! k2boarder3187 96-98 1 April 2nd, 2007 10:06 PM
Which Way Should I Mount The Subs? scrapdaddy jr. Audio/Video 9 September 19th, 2006 04:10 AM
where can i mount? KaZpeR General Tech 8 July 19th, 2006 11:22 PM
