plug gap
Old September 12th, 2007, 06:41 PM   #1
89bluecoupe's Avatar
89bluecoupe is on a distinguished road
plug gap
i have a 50 shot of n2o and 6lb of bost on a stock bottom end, stock heads, edelbrock rpm2 intake with 30lb injectors,70mm throttle body, 76mm c&l mass air and an msd 6al box with a 3 step digital retard. the plugs are autolite 24's. What plug gap do u guys recommend and what fuel pressure?
fuel pressure is at 42lb right now
plug gap is at .030
i was running just the nitrous at 125 shot no blower.
Old September 12th, 2007, 10:48 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
Fuel pressure is fine where it's at
but gap your plugs to about .040
Old September 13th, 2007, 02:22 AM   #3
thanks, but what if i up the nitrous to an 80 shot will the gap be allright at .040?
Old September 14th, 2007, 12:45 AM   #4
TurboLX's Avatar
.042 should do the trick
Old September 14th, 2007, 01:37 AM   #5
thanks for the help!
Old September 14th, 2007, 06:49 PM   #6
TurboLX's Avatar
anytime
Threads Similar to: plug gap
will a 4 plug head replace a 8 plug head CooolCobra 2.3 Mustangs 5 September 18th, 2007 11:12 PM
spark plug help mm49271 V6 Mustangs 3 February 5th, 2007 07:14 PM
Plug Gap On A 94 5.0? carviperblue 94-95 2 September 11th, 2006 01:09 AM
Plug gap on a 94 5.0? carviperblue General Tech 2 August 31st, 2006 04:56 PM
plug gap Bill 5.0 Mustangs 8 December 29th, 2005 11:52 PM
