Eaton M90 S/C modification
Old July 29th, 2006, 09:47 PM   #1
MSTNGRCR13's Avatar
1986 Mustang LX
MSTNGRCR13 is on a distinguished road
While at work, I got a wild hair across my arse and decided to do a modification that no-body in my shop has heard of anyone else doing, least of all around this area. I am deciding on installing an Eaton M90 S/C onto my 3.9 and was wondering if anybody here has any info on specs for compression, belt length, etc. or can direct me to sites wher I can find the info. I can tell you that the S/C has come off a 93 Supercoupe and will be rebuilt and cleaned up prior to installation. Any help here will be greatly appreciated. Thank you all.
AMP Performance
Old July 29th, 2006, 10:04 PM   #2
Drgnracin72's Avatar
that is a pretty common swap! theres one or two people on here that have done it that can guide you in the right direction
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old July 29th, 2006, 11:53 PM   #3
MSTNGRCR13's Avatar
1986 Mustang LX
Thanks for the help. I did some more research and found some info on v6power.net about it. Thanks again.
AMP Performance
Old July 30th, 2006, 12:06 AM   #4
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
I am not sure about the feasability of doing that swap on the 04's since they have different heads. Make sure you will not have issues first.
Old July 30th, 2006, 08:28 AM   #5
Roadhawg is on a distinguished road
Well you could used the SC singleport heads in place of the splitport heads.
2003 Mustang Mach1
1995 Thunderbird LX 4.6L;
1995 Mustang 4.2L; Eaton MPX Supercharger, 11.61 @ 118mph
Threads Similar to: Eaton M90 S/C modification
iac gasket modification laser_red_3.8 V6 Mustangs 13 September 24th, 2007 11:29 PM
Would Either Of These Engines Fit With Little Modification? energiesource 99-04 4 October 24th, 2006 10:02 AM
V6 CPU Performance Modification Assessment davigf V6 Mustangs 19 August 3rd, 2006 10:23 PM
h pipe modification militarygt 5.0 Mustangs 5 July 31st, 2006 09:22 PM
I Need Help with Modification Ideas missmichelle V6 Mustangs 7 July 30th, 2006 10:44 PM
