TSB 07-20-3 Cable Tension Noise - Built before 12/01/2006
Old September 27th, 2007, 06:53 PM   #1
ujslost's Avatar
Publication Date: September 24, 2007
FORD: 2005-2007 Mustang
ISSUE:
Some 2005-2007 Mustang Convertible vehicles, built before 12/1/2006, may exhibit a tick, pop, rattle, snap, creak type noise that sounds like it originates above the front door glass area and/or convertible latches. The concern is caused by a stick/slip condition between the cable and the top. The cable runs from the number 1 bow to the number 5 bow and maintains the shape of the window opening. The noise resonates through the cable to the number 1 bow.
PART NUMBER PART NAME
8R3Z-7652806-A Tension Cable - RH
8R3Z-7652807-A Tension Cable - LH
W707504-S303 Rivet
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources
Old January 18th, 2008, 12:31 AM   #2
00mustanggt is on a distinguished road
thanks
2008 H2 Hummer
2008 Jeep Wrangler
2008 Holiday Rambler (Another Motor Home)
2007 Holiday Rambler (Another Motor Home)
2006 Holiday Rambler (Another Motor Home)
2006 F-150 Harley Davidson (For Sale)
2006 Jeep Grand Cherokee 5.7L Hemi, and Much More
Threads Similar to: TSB 07-20-3 Cable Tension Noise - Built before 12/01/2006
TSB 07-19-1 CONVERTIBLE TOP WEAR - BUILT BEFORE 10/11/2006 ujslost General Tech 1 September 20th, 2007 10:41 PM
Tension Pulley MustangMatt96GT 96-98 8 April 24th, 2007 10:57 PM
2005 auto mustang vibration noise/ rumbling noise ozan169 2005 - 2010 4 March 13th, 2007 05:31 PM
Gas Pedal Tension MSTGGT00 99-04 12 December 22nd, 2006 08:55 PM
2006 Std Brake Noise casey V6 Mustangs 10 September 5th, 2006 05:23 PM
