Look Ma! My First Post!
Do I need a T-Rex for a Procharger P1SC?
I just bought a used P1SC for a '95 GT. The original kit comes with a inline fuel pump which was not in my kit.
I already installed a in-tank Walbro 255lp fuel pump. Do I still need a inline pump? I resently installed 30# injector and 30# Draw thru MAF. However, the kit I bought came with a 42# blow-Thru MAF. Should I: 1. install 42# injectors - or, 2. get the 42# Blow thru MAF recal to 30# - or 3. leave the it as is and have the tuner tune for a 30# Draw thru MAF? |
youwill not need the inline pump. ut would be wise to change up to he 42#, but the 30# might be able to take it. what kind of boost should you be making?
1998 Ford Mustang GT
the supplied inline pump most likely flows less than your 255 lph intank so it would probably be a hinderance
1987 Mustang GT
i thought you need an inline to keep up with the volume needs of the boost. I have a 255 lph in tank pump and have a t-rex inline sitting in the box that I was going to install. Im going to be running about 8 lbs of boost with 42 lb injectors and no fmu .
Threads Similar to: Do I need a T-Rex for a Procharger P1SC?
| Procharger P1SC vs. D1SC | marcfiebka | 99-04 | 11 | December 30th, 2008 08:17 PM |
| Pro P1SC vs Vor V2SQ | Mach Boy | General Tech | 1 | November 3rd, 2007 07:24 PM |
| 01 gt w/ P1SC | 00GT | 99-04 | 30 | September 21st, 2007 12:18 PM |
| Kenne Bell intercooled or Procharger P1SC for 2v GT? | Bigb2000GT | 99-04 | 30 | May 11th, 2007 01:32 PM |
