Bottle Warmer???
Old October 1st, 2007, 12:02 AM   #1
too slow
95blackbeauty is on a distinguished road
Send a message via AIM to 95blackbeauty
Bottle Warmer???
ok so i have a 100 shot on my 95 5.0 and i was recently noticing that when the pressure gets low it doesnt like to spray. I still have nitrous but it wont pray. I noticed the other day that when my car had been in the sun the pressure went up. Should i invest in a bottle warmer to get the remaining nitrous to spray? would that solve my problems?
95 gt H.O. Udp's, Pypes O/r X, flowmaster 40's,CAI, 3.73 gears, C&L 76mm MAF,GT40p's, Shorties, 1.6 rr's,Gt40 manifold, short throw, Back Seat Delete
BOOSTED
Old October 1st, 2007, 01:06 AM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
a bottle warmer is always a smart investment. pressure needs to remain around 950psi to get correct hp levels. it might solve the issue but it might not. i had a nitrous delivery problem in mine not to long ago and came out to be a kink in the nitrous main line. check the nitrous filter, make sure bottle is fully open, all wire connections are good, system fully purged out, good contact on wot switch, etc. just go back and recheck everything.
Old October 1st, 2007, 12:42 PM   #3
too slow
i have checked everything and it sprays just fine until i get low on the gas. but my pressure was at like 300 psi. so im thinking a bottle waremer is gonna help me out. thanks you for the reply.
BOOSTED
Old October 1st, 2007, 01:09 PM   #4
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
when you get down to the last 2 or 3 pounds, you aren't going to be able to get enough pressure in the bottle to spray correctly.
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox
Old October 1st, 2007, 01:55 PM   #5
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
Some systems need different pressures -
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old October 1st, 2007, 03:32 PM   #6
too slow
so pretty much no matter what when my bottle gets to a low level of nitrous i wont be able to spray it? That sucks cuz they are gonna just empty it when i take my bottle to get filled.
BOOSTED
Old October 2nd, 2007, 09:39 PM   #7
2004 GT
slow....
pa.ulB is on a distinguished road
Send a message via AIM to pa.ulB
yeah pretty much, when you get to really low pressures it wont work
2004 Crimson red GT
saleen s/c, full bolt ons
Old October 2nd, 2007, 09:40 PM   #8
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
iTrader: 10 reviews
you don't have to empty it, they can just refill the used nitrous. so if you have 3 pounds in the bottle they will put 7 back in it. why pay for nitrous that you already have.
but you do need to empty the bottle all the way every so often because nitrous will go bad
Old October 3rd, 2007, 02:09 AM   #9
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
the big companies recommend 950psi. that is also the pressure they rate their power.
Threads Similar to: Bottle Warmer???
bottle opener GTsetGO General Tech 5 June 1st, 2007 10:07 AM
Bottle pressure = HP? acmillr General Tech 20 April 5th, 2007 06:23 PM
where to put my bottle? militarygt General Tech 18 July 31st, 2006 01:43 AM
Will a NX bottle warmer work with a NW kit? Aliate X General Tech 2 October 22nd, 2005 12:16 AM
