Tie Rod Replacement
Would it be best off to change ball joints while im at it or is just doing tie rods fine
and i will need 2 correct or is there more than one on each side i don't know a thing about this
2000 V6 Performance Red @ Cardomain Was fun but a waste... 1987 LX Hatch | Soon to be a 600hp monster |
1999 Ford Mustang V6
i would do the ball joints too, especially if the boots are ripped. as for the tie rods they only adjust your toe, and not caster/camber so with a toe scribe or (homemade verison) you should be able to get it back within spec.
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
well im saying with i had the car jacked up and went to shake the tire it made a squeeking sound... some people said just replace the tie rods?
If the ball joints are bad, replace them. If not, leave them alone. If you have extra cash and the car has alot of miles on it then it wouldn't hurt to replace them.
what are the showings of them bad? and the car has 55,xxx on it, what is all needed for tie rods being replaced
look for torn or severly dry rotted boots. if torn then they are water contaminated
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
jack the car up and remove the tie rod end from the spindle. remember to break the lock nut before removing though. now turn the wheel back and forth. if it still squeeks,you're gonna need ball joints
come on now im the average joe here... it sounds so simple but just have no clue what any of that means
Threads Similar to: Tie Rod Replacement
| MAS replacement? | 1995svtcobra | 94-95 | 0 | August 11th, 2007 08:55 AM |
| Fog Light Replacement | Vettefast | 2005 - 2010 | 7 | August 8th, 2007 01:39 PM |
| Seat Replacement | silverstang23 | 99-04 | 3 | July 10th, 2007 12:10 PM |
| Key Replacement...?? | 98mustangfla | V6 Mustangs | 7 | June 11th, 2007 03:50 PM |
| Floor Pan Replacement | jtillery | 5.0 Mustangs | 3 | November 29th, 2006 11:48 AM |
