Discussing aftermarket tach's in the General Tech Forum. ok can anyone tell me why we are supposed to hook up an autometer tach ...
Old August 12th, 2006, 07:20 AM   #1
ttop5.0's Avatar
aftermarket tach's
ok can anyone tell me why we are supposed to hook up an autometer tach to the negative side of the coil, i thought that was supposed to be aground? How are you supposed to get a reading from a ground????
Old August 12th, 2006, 08:25 PM   #2
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
The negative side of the coil is pulses which triggers the tach. Its not a ground, its negative.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old August 14th, 2006, 02:31 PM   #3
well Im going to say the same thing but look at the old breaker point dist`s. the negative coil wire runs to the points, the negative is what controls the firing of the coil on the breaker point dist, when the point opens on dual points one charges the coil up (the common step-up coil) then when the second one opens and breaks the contact it causes the coil to fire through the post to the dist rotor arm. Same basic setup in modern electric and hei dist setup. My mercury has a factory tach and has 2 wires that hook up to the negative on the coil and two on the positive (one from the positive comes from the key switch and the other one runs from the post on the coil to the solinoid on the starter so when you crank over the engine it fires the coil and gives power to the starter)
Old August 17th, 2006, 09:12 PM   #4
If you have an MSD you need to plug it into the MSD box and not the coil.
Threads Similar to: aftermarket tach's
Aftermarket springs? gregkelley Suspension 4 August 27th, 2007 05:50 PM
AFTERMARKET BLOCK 50COUP332 5.0 Mustangs 21 April 13th, 2007 10:50 PM
Aftermarket AC extropy Classic Mustangs 0 January 22nd, 2007 01:44 PM
aftermarket headers 1990CA50 5.0 Mustangs 14 January 4th, 2007 09:37 PM
Help! (Aftermarket Hood) DEL_SPEED 99-04 7 January 4th, 2007 06:19 AM
