MSTRB8N & MDR8N
2021 Mustang V15
Quad Turbo with nawz
Best Gears With A Turbocharger?
i tried searching.. couldn't find exactly what i was looking for..
what would be the best gear ratio for a single turbocharger? i was thinking 3.55.. EDIT sorry, its currently auto, but before the turbocharger, i'm planning on doing a 5 speed conversion
MM 1 am boner crew Cars and mod list in garage i like veiny meat sliding between my buttcheeks |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
depends on power and set up. a friend of mine had 4.10's in an auto with a s/c and it was great. with an auto you can get away with a steeper gear easy. going to a manual will change that drastically. i have 4.10's and hate them, i am going to a taller slick and probably 3.73'sif i dont get the results that i want. i ran 3.55's for a while, but it will take a lot of power to make the 3.55's work correctly.
booooost'd
2007 Mustang
you want 4.10's with a turbo or centri, 3.73's with a Twin Screw.
![]() Jucostud's Official Build Thread 1988 LX HATCH 5.0 - FOR SALE $5,000 OBO 2007 vortech gt - SOLD! Looking for next project |
#5 | |
1988 Mustang LX Turbo
What are you saying!?!?!
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
muneris pro ego
definitely 3.55 or under for turbo. 3.73 is good for SC. 4.10 is good for N/A autos
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
#7 | |
RLY SRS
Turbos love RPMs...
I think with the 5.0 a set of 3.27's would be perfect... |
#9 | |
Re: best gears with a turbocharger?
An automatic will hold the boost when you shift. With a manual it will dump the boost between gear changes.
#10 | |
I am runnin 3:73s on my turbo fox, and I break the tires loose in third gear when the boost hits (first and second gear are pointless). Do yourself a favor and get some 3:27s or maybe 3:55s if your not running too much hp. This is (of course) all dependent on what tires and suspension you'll be running. I have full autocross suspension with 17s and G-force TAs.... not so drag friendly... but fun as hell to drive to work every once in a while
69 convertible: 302/ DART heads/Z303 cam/Vic Jr./ 650 DP Tremec w/ 4:10s 86 hatch: 302/ Edel Al. heads/ F303 cam/ twin Garret T3 turbos 10 psi intercooled 52# injectors MegaSquirt II EMS http://www.youtube.com/watch?v=_urWMgS_IRQ |
omfg!!! 4.10's with any FI would send ur tires to hell!
For any turbo setup, i would stick under 3.55... infact i would just stick with stock gears. once u hit that max boost its gonna drop a load on that drivetrain and if u have a short gear, ur gonna spin no matter what. But with 3.27's u hit that boost, u'll catch trac and just GO!!!!
don't mean to hijack the thread.. but why should he get something like 3.27s or 3.55s on his car with his turbo? im gonna centri s/c mine but 3.27s are stock and i don't dig em.. is it just different with the 5.0 motors? i was thinking frpp 3.73s or 4.10s in mine..
![]() Mods: Fidanza Al Flywheel, Steeda UDP, EMP/Stewart Components WP, PP Plenum, K&N FIPK, Mac Prochamber, Magnapacks WhtPny's Videos
I explained it... kinda. As soon as you hit that boost, if you have a short gear ratio... ur gonna spin. 4.10's will most def spin like crazy 1st-2nd and probabably some of 3rd, 3.73's will most likely spin like a bitch 1st-2nd (if you have a TC, 3.73's are ideal for a SC). An ideal gear ratio would be a 3.55 for a TC 4.6PI and 3.27's in a 5.0. I say 3.27's in a 5.0 because their tq and hp max is reached at a much lower rpm than a modular engine.
you will spin all gears with just about anything higher then 3:55's
#16 | |
#17 | |
#18 | |
go with 4.10 gears
Just buy the 4.10s and get some 285 35 - 18 drag radials like I did and freaking blow off the tires in the first three gears. People watching will cheer at you and think your cool. My turbo laughs at my 555r's.
Threads Similar to: Best Gears With A Turbocharger?
| turbocharger sizes | BWAL | General Tech | 26 | May 8th, 2008 08:42 PM |
| Supercharger OR Turbocharger | trueballerisme | V6 Mustangs | 150 | April 24th, 2008 01:16 AM |
| turbocharger question | trueballerisme | General Tech | 24 | February 23rd, 2007 10:56 PM |
| Supercharger OR Turbocharger | trueballerisme | General Tech | 17 | February 6th, 2007 04:21 PM |
| Im thinkin about getting a turbocharger | Wesf90 | 99-04 | 13 | December 14th, 2006 09:43 PM |
