Destroying A Myth, Backpreasure
Old August 13th, 2006, 12:39 AM   #1
Sa-WaitNoMustang900Turbo is on a distinguished road
this is what ive been saying for at least two years now. I could never understand how backpreasure could = torque,i.e. I could never figure out the physics behind "exaust scavenging" nor had i seeen it for my self (i have only felt low rpm GAINS with loss of back preasure)
appearently many others agree with me
example:
http://www.uucmotorwerks.com/html_pr...torquemyth.htm
God... That Euro import guy is really starting to get on my nerves... my car can only beat his in a strait line(maybe)
Old August 13th, 2006, 08:23 AM   #2
stangliter04's Avatar
stangliter04 is on a distinguished road
Peanut butter open headers time
* BTW good info.... I always thought the same.
Silver 04 Cobra... with a Whipple
Old August 18th, 2006, 05:09 PM   #3
machy is on a distinguished road
open headers is to dam loud
Old August 22nd, 2006, 03:02 PM   #4
Milner62 is on a distinguished road
lol yep open headers are loud. One reasion why im going with a custom setup exhaust system i put together myself which has larger tail pipes and muffles than the pipes before the mufflers
Old August 26th, 2006, 01:57 AM   #5
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
open header?! wow i crack my exaust manifold(header) and it was only on one side and that was loud! open header is loud, idk id jus cut the exaust at the mufflers, thats loud too and nice sounding
[SIGPIC][/SIGPIC]
Acmillr loves me
Old September 15th, 2006, 06:47 PM   #6
Screemin3o2 is on a distinguished road
Send a message via AIM to Screemin3o2
It all depends on the cylinder head design cam design and a few other variables in my opinion. We hooked a built 355 nova on the dyno last week. It made 7 less hp when he ran open headers from full exhaust and his torque and horsepower curve weakened dramatically. Exhaust scavaging and backpressure are not a myth. If you have a decent knowledge of how airflow acts and you study scavaging and the backpressure effect, it does make since. I have been saying this ever since I studied deeply into engines and every other part of a car, everything is a science. If you add something to your car that scientifically will increase your power band, it will. If it does not, it is because there is an opposing force you have not recognized.
I.E. I bought a 75MM throttle and bolted it to my stock engine because obviously if it is bigger then it will provide more airflow. Then I began to understand airflow and realized how dumb I was to think if I did not match the port from my tb to my manifold or I did not increase every part of my induction system, I would still get a power increase. If anything I lost it and dramatically decreased the curve. You can't hook a holley systemax intake on your car and bolt it next to stock e7's and expect to gain any horsepower. It's the same with exhaust. Switch from a 1 5/8" headers to 1 3/4" or even larger on your stock engine and see how much more of a dog it is.
95 Mustang GT
Slow Bolt On Car
www.steelcitystangs.com
Old September 15th, 2006, 07:46 PM   #7
mdvaldosta's Avatar
11.47@120.58
Backpressure assists with cylinder scavaging, therefore if done properly, will actually increase power and torque througout the curve. Typically, the less backpressure, the higher the torque curve moves in the rpm range (usually increasing peak horsepower and hurting peak torque).
Like screamin noted (the fugger knows his sh*t), theirs more to it than just backpressure.
Old September 16th, 2006, 07:11 PM   #8
I lost count of how many things in that article are wrong or don't make since. The guy is saying too little backpressure won't burn valves. Well hell, make it 0 backpressure and run an engine straight out of the exhaust ports with no headers or anything and see how quick it takes to burn a set of valves
95 Mustang GT
Slow Bolt On Car
Old September 19th, 2006, 11:08 PM   #9
carbs can act differently with changes in back preasure than a computer controlled engine, hell on my mower when i ran a strait pipe i had to retune the carb to run richer, i lost so much power off the bat, but when i adjusted the a/f it ran about 1hp stonger!(seemed like, no mower dyno lol)
sure you could see an increse in power with more back preasure, but in theory if your a/f is precise almost no matter what (as in a bmw), you should see an increase in power and torque with a drop in back preasure(no offense intended to mustangs v8s, but stock a/f test vs stock a/f test, bimmer wins all the way, making a drop in back preasure better on its engines)
remember IN THEORY, and as those who understand how engines work rather well, the smaller displacement/combustion chamber the more acurate and evenly dispersed the a/f will be adding to other obvious outcomes in tuning, also at low rpm speeds the a/f dispesion in any engine becomes more uneven making other obvious outcomes come true, especially on a performance engine with an agressive cam
also port matching reduces backpreasure by making the flow less turbulent (i nor this article ever said that increasing the diameter of stuff which mismatches port decreases backpreasure)
back preasure has no effect on burning valves, a/f does(or maybe an open block and COLD AIR hitting the valves does lol)
edit: now that i have re-read the aritcle I again see no place where he is technically wrong, he didnt say much, and the stuff he(and I) did say logically coincides with what you are saying(to an extent of course) whether you can see it or not
edit again: im not trying to argue, only trying to show the truth to people who can understand what it is talking about, many of your comments only confirm what ive been saying, yes the stuff associated with backpreasure is complex in some ways, but again, it is not the backpreasure that is directly causing the effects, it is the a/f!
Old September 19th, 2006, 11:29 PM   #10
If you run an engine straight out of the cylinder head, it will burn the valves because there is no vacuum to get the gases out of the chamber.
95 Mustang GT
Slow Bolt On Car
Old September 19th, 2006, 11:44 PM   #11
well, again im pretty sure its the cold air "burning" the valves on an open block, and that there is more preasure in the exhaust piping than in the ambient air despite the fact thae exhaust moves a lot faster(heat, moving mass of other air, and compression against walls cancels out moving fast) so there sould be more of a "vacuum" in ambient air, allowing the exhaust to be pushed out faster, in theory.
btw, nice avatar
Old September 20th, 2006, 07:29 AM   #12
I'm not understanding how you are saying cold air will burn a valve.
95 Mustang GT
Slow Bolt On Car
Old September 20th, 2006, 10:16 AM   #13
Roadhawg is on a distinguished road
You need a small amount of Back Pressure. This will prevent too much of the intake charge from being pulled into the exhaust system when both intake and exhaust valves are open.
2003 Mustang Mach1
1995 Thunderbird LX 4.6L;
1995 Mustang 4.2L; Eaton MPX Supercharger, 11.61 @ 118mph
Old September 24th, 2006, 10:36 PM   #14
well, on some cars(boosted and some with variable cam timing, new mustang GT included i think) at lower rpms and part throttle where the backpreasure would actually matter for valve overlap (fuel economy) there probalbly is relitivly little to no valve overlap, making backpreasure completely undesireable. Not to mention the carbed n/a performance cars which dont care in the least about fuel economy or low rpms where the a/f is not exact.
and do you mean how can cold air hit/affect valves on an open block, or do you mean what will cold air do to incredbly hot (metal remember) valves?
Old October 14th, 2006, 10:51 AM   #15
Bish's Avatar
Bish is on a distinguished road
Man, I'm sitting here after reading all this and have come to one simple conclusion. . . . .
I don't know shit.
I'm going to have to reread this several times and maybe some of it will start making sense to me. I digress, for the time being I'm not changing anything until I understand this better.
Thanks for the awaking, it's greatly appreciated.
Bish
Old October 14th, 2006, 10:53 AM   #16
RLY SRS
ChrisJ's Avatar
ChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud of
iTrader: 9 reviews
I lost 2rwtq when I took my cats off but gained around 2rwhp...
There is such thing as back pressure...
Facebook
Google+
Old October 14th, 2006, 02:38 PM   #17
I guess some people have different ideas of what back pressure really is and what it causes. That changes nothing. If something happens over and over again with different cars and the same part changes, etc. no matter how you look at it or what you call it, the way it works is still the same. No matter what, if you change the backpressure in your exhaust or wherever your power and torque curves will change therefore its not a myth.
95 Mustang GT
Slow Bolt On Car
Old October 14th, 2006, 02:41 PM   #18
I don't know shit.
gotta start somewhere as long as you are interested in it. Just start at the beginning and keep reading. You think some of the best techs know everything just because they have experience? I guarantee they studied some of it sometime in their life.
95 Mustang GT
Slow Bolt On Car
Old October 14th, 2006, 09:20 PM   #19
TENGRAM is on a distinguished road
now i'll start by admitting that i only read most of these comments...not the novel posted by Sa-WaitNoMustang900Turb...so maybe someones already mentioned this.
backpressure is bad. period. exhaust velocity is very important and though back pressure can aid in exhaust velocity it is much better to have velocity without back pressure. appropriately sized exhaust is needed to produce maximum low end power and torque.
89 GT t5 3.73
www.my5oh.com/
Old November 5th, 2006, 01:59 PM   #20
SquirrelNutz is on a distinguished road
What pipe size should I use for a street application?
In general, the following guidelines should be applied for street applications.
2"
tubing
up to 100 hp per pipe
2.25"
tubing
up to 160 hp per pipe
2.5"
tubing
up to 200 hp per pipe
3"
tubing
up to 300 hp per pipe
THIS IS FROM THE FLOWMASTER SITE.... I dont know where some of yall are getting your information but you do need backpressure there is no myth there! Too much backpressure is bad and too little backpressure is bad and that is fact!
www.myspace.com/derrickmcphate
Threads Similar to: Destroying A Myth, Backpreasure
Destroying Dyno Myths... 56K Beware! 1slo5.0 5.0 Mustangs 59 February 20th, 2011 11:47 PM
whats some good car myth for myth busters White Thunder The Clubhouse 24 November 4th, 2007 09:11 PM
Intake Spacer. Fact or Myth? TheUNZippee! 2005 - 2010 17 May 23rd, 2007 11:17 PM
Terminator destroying modded srt-4 PureVolume707 Videos 12 March 27th, 2007 08:32 PM
